Question about Canon Pixma MP500 All-In-One InkJet Printer
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
Posted by davidrace2 on
Anonymous
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Posted on Jul 21, 2009
Anonymous
  • 92 Answers
This product can be used with Windows Vista.
  • To use it with Windows Vista, you must install the driver software for Windows Vista.
  • The Windows XP drivers for your product cannot be used under Windows Vista.
  • Easy-WebPrint and PhotoRecord do not support Windows Vista.
Upgrading from Windows XP to Windows Vista :
Before upgrading your OS from Windows XP to Windows Vista, delete / uninstall all the Windows XP driver software first; then, upgrade the OS to Windows Vista and install Vista driver software.
If you have already upgraded your computer's OS to Windows Vista :
Delete / uninstall the Windows XP drivers before installing Vista drivers.
Software for Windows Vista
How to confirm the types of software CD-ROM
  • The supporting software versions vary depending on the types of software CD-ROM.
  • To distinguish the type of your CD-ROM (A / B / C), check the descriptions of [ 1 ] and [ 2 ]. (Refer to the illustrations below.)
  • The illustrations below shows the CD-ROMs for the MP500. The model name and background color vary depending on the printer model.
The description of [1]:
  • CD-ROM A: The model name you are using
  • CD-ROM B: "Setup CD-ROM for Microsoft Windows Vista"
  • CD-ROM C: The model name you are using
The description of [2]:
  • CD-ROM A: 2.0 or later
  • CD-ROM B: 1.0
  • CD-ROM C: 1.x
MP Drivers
  • Since the printer driver and WIA driver for this machine are pre-installed in Windows Vista, you can use it as a printer or scanner just by connecting it to your Windows Vista computer.
  • However, printing and scanning may not be performed correctly under this condition.
  • In such a case, install MP Drivers for Windows Vista.
If you have CD-ROM A:
  • You can install the MP Drivers that support both versions of Windows Vista (32 bit / 64 bit).
If you have CD-ROM B:
  • You can install only the MP Drivers for Windows Vista 32 bit version.
  • However, you can download/install the software for Windows Vista 64 bit version from the Canon WEB page.
If your CD-ROM is "C" or you do not have any CD-ROMs:
  • Download/install the MP Drivers each for Windows Vista 32 bit / 64 bit from the Canon WEB page.
You can confirm whether the OS of your computer is Windows Vista 32 bit version or 64 bit version; click System in Control Panel of Windows Vista to see System type.
MP Navigator / IJ Network Driver / IJ Network Tool / Easy-PhotoPrint
The software you can use varies depending on the machine you are using.
  • You can install the software that supports both versions of Windows Vista (32 bit / 64 bit).
  • You can install only the software for Windows Vista 32 bit version.
  • Download/install the software each for Windows Vista 32 bit / 64 bit from the Canon WEB page.
PhotoStudio / Presto! PageManager NOTE: The manufacturers do not guarantee the operation under Windows Vista.
  • After installing the CD-ROM, confirm the Windows Vista support in each application manufacturer's web site, then follow the instruction they provide.
  • For how to install the software for Windows Vista from the CD-ROM, see the information at the bottom of this page.
If you have CD-ROM C:
  • After installing the software from the CD-ROM, confirm the Windows Vista support in each application manufacturer's web site, then follow the instruction they provide.
  • For how to install the software for Windows Vista from the CD-ROM, see the link at the bottom of this page.
If you do not have any CD-ROMs:
If the software has already been installed, confirm the Windows Vista support in each application manufacturer's web site, then follow the instruction they provide.
Application
Manufacturer
Homepage
Photostudio ArcSoft www.arcsoft.com Presto!PageManager NewSoft global.newsoftinc.com
Nuance OmniPage SE
Before attempting to install OmniPage SE, please visit the Nuance website to acquire the OmniPage SE update that allows Windows Vista support with this application. Then carefully follow the installation instructions provided.
NOTE: This update is only compatible with OmniPage SE 2.0, 3.0 and 4.0.
Application Name
Manufacturer
Homepage
OmniPage SE Nuance www.nuance.com/vista/omnipage/canon To download the software for Windows Vista 32 bit / 64 bit, click the Canon MP500 all in one printer is not compatible - driver_download_link.jpgink in the Downloads section of the product support page.
driver_download_link.jpg NOTE:
  • The Windows XP software cannot be used under Windows Vista.
  • Before upgrading your OS from Windows XP to Windows Vista, delete all the Windows XP software first; then, upgrade the OS to Windows Vista and install Vista software.
  • If you have already upgraded your computer's OS to Windows Vista, delete Windows XP software before installing Windows Vista software, if any.
How to confirm the version of Windows Vista (32 bit / 64 bit)
To chCanon MP500 all in one printer is not compatible - vistaversion1.jpgf the Windows Vista you are using (32 bit / 64 bit), follow the procedure below.
1. Click Control Panel iCanon MP500 all in one printer is not compatible - vistaversion2.jpg
2. Click System and Maintenance.
Memo: In "Classic" display, click System. 3. Click System.
vistaversion3.jpg 4. The basic information about your computer is displayed. Check the version shown in System type.
Posted on Apr 26, 2009
Is a canon pixma mp500 compatible with windows vista? and how?
it should be, any canon product is compatible with windows vista
Apr 10, 2010 | Canon Pixma MP500 All-In-One InkJet...
Will not scan... Apparently, the scanner with this canon printer (Prixia MP500) will not work with Windows Vista. What can I do?
Your machine is compatible with Windows Vista. Uninstall whatever drivers you currently have installed, then download and install the drivers from this link. Be sure and also install the MP Navigator (listed under Software), which provides the scanner interface program.
Mar 03, 2010 | Canon Pixma MP500 All-In-One InkJet...
Scanner does not work with vista has compatability probs. any idea
You can try and download the 32 bit driver for XP and install it using compatibility mode. But there are a lot of cannon printers/scanners that don't work with Vista, and most of these even need some finessing to work in Windows 7.
Dec 03, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 doesn't work since I got new computer "with VISTA". Where do I go to find updated drivers that will allow compatibility with Vista?
you can download the driver for vista here http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=11995
Mar 28, 2009 | Canon Pixma MP500 All-In-One InkJet...
Printer not working with Vista
No problem. These are the links to Canon Support Website where you can download the drivers. There is two versions a 32bit and 64bit. It all depends on which OS u have.
32bit version:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=11995#DownloadDetailAct
64bit Version:
Any questions..I'll be glad to help.
Jan 27, 2009 | Canon Pixma MP500 All-In-One InkJet...
Scanner stopped working with new computer
Windows Vista. You now have to have the drivers for the VISTA OS . Here is your models support page to download the drivers form CANON..
Dec 31, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon pixma500
I hope it helps!!!
Nov 22, 2008 | Canon Pixma MP500 All-In-One InkJet...
Mp 500 printer driver software
Try the Canon website for updated drivers.
If they don't have one, try using the compatibility wizard.
Download the latest driver available from the canon web site
To open the program compatibility wizard
1. click the Start button
2. click Control Panel
3. click Programs
4. click Use an older program with this version of Windows
5. browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
Dec 15, 2007 | Canon Pixma MP500 All-In-One InkJet...
Windows vista unable to install my canon pixma mp500
First download and install the latest drivers for Windows Vista. Then try connecting the printer. The latest drivers can be obtained from: www.download.com/BJ-Printer-Driver-Canon-Pixma-iP1500/3000-2116_4-10555901.html
Sep 27, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
old marine
old marine
efs_perpends
efs_perpends
