Open up Control Panel and navigate to IDT Audio Control Panel.
On the right hand side, there would be an image depicting the jacks available on the 1555. Left click on the respective jacks and change them corresponding to the 5.1 outputs.
I posted this solution for someone with a studio 1537, I'm not sure it will work for 1555, but give it a go. Put the black cable into the microphone jack, orange into the jack next to that and the green one into the furthest right jack. Then open up the IDT Audio Control Panel (Control Panel -> Additional Options -> IDT Audio Control Panel) and in the far right panel (Jacks), click the far right jack picture and it should come up with a drop down selection. Select 'Device: Front Speakers' and the rest should also change. Enjoy I hope this helps
You can plug the speaker pin in the port provided for audio out which is shown by the headphone sign
printed along with them.,
you can also consult the guide given by the compan y for the proper port specificationa and selection
SOURCE: My Dell Studio 1555 laptop does not read the dvd drive
Microsoft Windows Vista
loadTOCNode(2, 'resolution');
Now go to the "Did this fix the problem?" section.
Back to the top
Microsoft Windows XP
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters
only. If you do not see the UpperFilters registry entry, you still
might have to remove the LowerFilters registry entry. To do this, go to
step 8.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
step 7.
dell studio 1555 bluetooth driver
