Panasonic CQ-VD7003U Car DVD Player Logo
Question about Panasonic CQ-VD7003U Car DVD Player
Security code. i bought my Panasonic CQ-VD7003U used off ebay and it asks for a 4 digit security code... i have no idea what the code is... any ideas?
  • 3 more comments
  • Anonymous Dec 24, 2007
    no id code.... i need 4 digit code
  • Anonymous Feb 09, 2008
    i on't have the code for my radio panasonic cq-vd7003u
    i desconect the cable power i no remenber id code
  • taylorball12 Nov 01, 2008
    i have the same problem and ive tried holding the right selection stick to the right for 10 seconds and it doesnt do anything
  • Anonymous Apr 11, 2009
    My stereo got boosted out of my truck!! Then we ended up getting it back from the police because we had registered it. (So always keep you make and model numbers on file) But when we re-installed it into my truck it was asking for the security code. I found your suggestions on her and it Works Great!!! Thanks!!!!
Anonymous
Its Easy!!!!!! Hold the right track button to the right or 10 secs and it works!!!!!!!!!
Posted on Feb 01, 2008
Anonymous
Hey just tried holding the joystick to the right for 10 seconds while the unit is on.The unit came on.This should help
Posted on Apr 10, 2010
Anonymous
  • 3 Answers
Hold down the fast foward button for 7 sec
Posted on Feb 07, 2008
Anonymous
I bought a panasonic stereo andi its asking me for a code and i do not know the code .i bought it used but in good conditions so i just wanted to know if i could do something about it.thanks
Posted on Nov 06, 2008
Anonymous
    An expert that gotĀ 10 achievements.
    An expert whose answer gotĀ voted for 100 times.
  • 626 Answers
According to the manual, there is not "default" security code. You will have to contact the MFR for support. Manual is here; http://www.retrevo.com/s/Panasonic-CQ-VD7003U-Car-Receivers-review-manual/id/312ag117/t/1-2/ Best of Luck.
Posted on Sep 29, 2007
Anonymous
That works Perfectly, You guys ROCK!!!
Posted on Nov 05, 2008
Anonymous
It just keep on asking for id code
Posted on Aug 04, 2008
Anonymous
  • 3 Answers
You need to ask the origional owner for the code.
Posted on Dec 08, 2007
1helpful
2answers
How to reset security code on panasonic cd player CQ-VD7003U
ID-CODE
ID Code Setting
Prior to operating this unit, it is advisable to assign a 4-
digit ID code for security. Once the ID code has been set,
the unit cannot be operated if the main power supply is
disconnected then re-connected. It is electronically locked
so that a thief cannot use the stolen unit unless that person
knows the code you have set.
The ID code operation must be performed only by the
person to whom the unit belongs.
Generally, it is not necessary to enter the ID code each
time when using the unit if it has not been disconnected
from the main power supply (car battery).
to 4 digits numeric code
default: none
How to set your ID code (for the first time)
q Enter an 4 digit ID code.
w Enter the same 4 digit ID code again.
How to change your ID code
q Enter the preset (old) 4 digit ID code. If the wrong ID
code is entered, a new ID code cannot be registered.
w Enter a new 4 digit ID code.
e Enter the new 4 digit ID code again.
How to cancel the known ID code
code is entered, it is not possible to cancel the ID code
function.
w Touch and hold until "COMPLETED!" is displayed.
The ID code canceling procedure is completed.
The unit now works without an ID code.
Note:
”Should your unit ever require service, cancel your ID
code before sending for repair.
”The ID code setting cannot be eliminated even by the
memory clear function.
”The inputted code is not displayed for your security.
0 9
Caution
”Record your registered ID code and keep it in a
secure location. (Fill in the ID code memo (a
page 46).) If you forget it, you will be unable to use
the unit. In case you forget the ID code, please
consult your nearest Panasonic Service Center.
4helpful
3answers
Tengo una panasonic CQ-VD6503u car DVD player y necesito el codigo para debloquear por favor
Hi
With due respect to your language can you please post your problem in english so that it will be easy to understand your query and reply accordingly.
Thanks for contacting fixya.com
How do I get the ID code on a Panasonic CQ-VD7003...
I have the same unit if you hold the right round stick knob to the right for 10 seconds while the unit is on it should unlock the unit if the previous owner didnt set a 4 digit code. I had the same problem and it worked good luck.
11helpful
2answers
I need 4 digit codes for a panasonic cq-vd7003u
i have heard that if you hold down the fast forward button for 7 seconds it will reset it
2helpful
2answers
Lost security code for my panasonic VD7003U DVD player for my car
call the panasonic costomer service they should have the code.
1helpful
2answers
I need a installation manual for my cq-vd7003u unit
HI,
this link contains the service/repair/help manuals how to help you
http://caraudio.manualsonline.com/manuals/mfg/panasonic/cqvd7003u.html
thank you,
vijay(vote for me)
2answers
Panasonic cq-vd7003u ipod video trouble
The problem is that the panasonic cq-vd7003u does not support that function which sucks cuz i have one 2 the slightly newer verision PANASONIC CQ-VD7005U does have that feature. so sorry.
11helpful
2answers
Id ccode
4-digit ID code security FOR CQ-VD5505W
8helpful
7answers
Bypass four digit code for panasonic cqvd7003u
i had the same problem. Set the code but if you leave uninstalled for too long then the code you set will not work.you hold the fast fwrd down until it turns on and reset code again.
Buzzing Noise
do you have subs? if so you have your amp wire to close to the RCA cable it interferes with the signal they have to be at least 6in away from each other or on the opposite side of the car if that does not work then idk check the hook up....
Top Panasonic Car Audio & Video Experts
 Francisco Mauricio...
Jeffrey Turcotte
Jeffrey Turcotte
Muzahura Frank
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
