1996 VS V6 commodore starts ok then stalls after a few seconds. Wont rev up. Fuel pump starts up for 2 secs then stops as it should. Can feel pulses in hose ok but not checked pressure yet . Fault code 12 only =all ok. Wot's happening. Sounds like low fuel pressure or possibly Crank Angle Sensor but no CAS fault codes. Any advice pls?
DJ
Have you checked fuel filter,check risistance on your throttle position sensor,could be faulty fuel pressure regulator,check the basics first,
I'm going through the same thing with my supercharged engine I think it's a crank sensor but I'm thinking alarm as well ill try well you guys no as soon as I work it out
Dont know had same prob trued sensors air intake throttle position ended up taking choke cable off starts first time every time now when it used to take twenty goes before it would idle any one know why
Has anybody figured this out I also just bolted a supercharger on and had the same problem
Yeah im goin through the same thing now , iv jus bolted up a supercharger and it starts fine then cuts out 2 secs late, wont rev and whenm trying to start with foot flat on pedal it wont start does anyone know wat is goin on??? cheers
