Question about Fuji FinePix Z10fd Digital Camera
How do I get to internal memory
How do I access internal memory on fuji z10fd camera?
    President:
  • 423 Answers
Remove the memory card and you should be able to see the images stored on the internal memory by pressing the playback "arrow" button. If it says no image found, there is nothing currently on the internal memory. With a memory card inserted, the camera defaults to the card only, and ignores the internal memory.
Posted on Apr 26, 2009
No matter what program I use, the fuji memory card that came with the camera, will not upload pictures into my computer. It will only upload pictures stored on the internal memory. But that's only 3...
That memory card isn't great, is it? You already got the 1.01 firmware upgrade to the camera, right? Try a card reader (and soon, a new 8GB SDHC card,) instead of making the camera suffer.
Aug 15, 2011 | Fuji FinePix Z10fd Digital Camera
All my photos have gone...when I turn the camera on...it states.....images recorded to internal memory...how do I get the photos from the internal memory.
Connect Your camera with the computer using data cable.First confirm if you installed your camera driver in the computer.Now the camera will detected and you can upload your photos to the computer.
Sep 04, 2010 | Fuji FinePix Z10fd Digital Camera
Photos I want aren't on my xd card but on internal memory????
You'll need to install the software that came with the camera onto your computer then connect the camera with the USB cable that came with it to your computer. The software will start when it senses your camera is connected and you'll be able to access the camera internal memory. Otherwise, you can copy the internal memory contents to the memory card from the camera itself from the menu system.
Feb 04, 2010 | Fuji FinePix Z10fd Digital Camera
How do I access the internal memory?
Sometimes the internal memory can only be accessed if there is no mem card present. If you have a mem card inserted try taking it out and see if you can access the internal mem.
Hope this helps!
Cheers
Sep 27, 2009 | Fuji FinePix Z10fd Digital Camera
Access to Photos on internal memory
The Copy command is in the playback menu. See the "Using Playback Menu" section of the manual (begins on page 75 in my copy). If you need a manual, you may download a copy here.
Jul 12, 2009 | Fuji FinePix Z10fd Digital Camera
How to transfer internal images to sd card?
Put memory card in camera, power up, go to menu and find copy option, select it and press ok.
That will copy picture files from internal memory to memory card.
Jun 17, 2009 | Fuji FinePix Z10fd Digital Camera
How do I access the internal memory? I believe
If you take the memory card out of the camera, you can go to playback and see exactly what's on the internal memory. If you see the images you are searching for, re-install the memory card and go to playback, again. You won't be able to see the internal memory any more. Press the menu button and go to the copy function. You will have the option to save images from the internal memory, to the card, and vice-versa. Save them from internal to card memory and you should have all the images saved from your camera to the card, for easier access to them.
May 18, 2009 | Fuji FinePix Z10fd Digital Camera
Getting pictures off internal memory
1....put your SD card in the slot...
2...turn cam on and go to playback menu
3....go to MENU/OK option
4...scroll down to COPY select ok
5....Then choose option INTERNAL memory to card and hit ok
Mar 23, 2009 | Fuji FinePix Z10fd Digital Camera
Fuji FinePix Z10fd Digital Camera Logo
527 people viewed this question
Top Fuji Cameras Experts
Ekse
Azam Ali
Level 1 Expert
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
