If you need an audio driver for your Asus P5GZ-MX mobo, why don't you just come out in English, and say so? http://support.asus.com/download/download.aspx?SLanguage=en-us
Would appreciate it if you would rate my solution. This tells me you have viewed it, and whether or not it helped you. Guests can join FixYa, and rate also.
You can't post conmments that contain an email address.
Hy nama sya febri Saya ada tv led polytron , saat dalam keadaan mati tv saya nyala kan dgn remote tapi tidak keluar gambar sedangkan ada suara dan lampu nya. Lalu saya coba matikan dan hidupkan lagi tetap sama gambar tidak ada sedangkan suara dan cahaya ada, setelah beberpa kali saya on of percobaan ke tiga smpai ke 4 lalu tv menyala dgn normal... kira kira kendala nya apa ya...pls di kasih pencerahan
Your computer uses a PCI-E X16 graphics adaptor so as long as there are enough connectors from the Power supply and it is rated high enough, it should work. If it will fit will depend on the form factor of your tower. You may need a half height card if you have a small form factor tower.
Halo kawan sebangsa,
Anda dengan gampang bisa dapatkan di links ini :
www.canon-asia.com
Atau
www.canon.com
Silakan dowload driver yg pas buat printernya.
Jika ada masalah , reply chatting ini ( jangan buat baru, agar berkesinambungan). sertakan email anda ( akan lebih baik, ) karena saya ingin customer indonesia dapatkan yg terbaik dari FixYa dgn gratis.
Salam, jangan lupa di vote / rating ya, Muntejaya FixYa
mohon solusinya ya bos...saya mau cari driver printer INDOR "LECAI 4000+"...Kalo tidak ada yg gratis..beli juga tidak apa2..,kira2 nyari/belinya dimana ya..bosss...???
The most common solution was this: open device manager click
"system devices" disable "microsoft UAA bus driver for high definition
audio" uninstall "UAA bus driver" make rescan devices (Note: Not all
had this step. You may want to skip it.) D.W. install realtek driver
the realtek driver includes the UAA driver too.Hope this
helps.
ASUS DRIVER P45GX-MX
