Computers & Internet Logo
Posted on Sep 27, 2007
PRINCETON LCD-15BLK MONITOR
Monitor is less than 2 year old. Just went blank. When you turn the power on, the power light comes on and the LCD shows red/pink with the proper display for about 1 second and then goes blank. I am going to reseat all connections, but wondered if it is a waste of time. Replacement LCD units are about $90, and a new one is about $300, so it is worth a little poking around time. Can anyone give me some direction here?
  • 3 more comments
  • tjzeus Sep 27, 2007
    Actually, the image is correct for that 1 second that you can see the picture.
  • Anonymous Jun 05, 2008
    When i turn on the monitor the light appears and I receive a visual for about 2 seconds and then it makes a fuzzy noise and goes blank.
  • this be me Jul 31, 2008
    Accusync 95F monitor for Mac desktop. The green power indicator shows the regular green light and then turns to amber. The screen stays black.
  • Anonymous Sep 04, 2008
    Princceton lcd monitor comes on for about one minute with a clear picture and then cuts out
  • Anonymous Jan 04, 2009
    i turn on the monitor, and it shows the desktop for a second, but then goes blank
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 15, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
637
Points
I had the same problem for the past couple of weeks: first it was intermittent and then it just went dead completely. Something you may want to try (depends on model, but worked on mine) is to disconnect the power cord to the back of the monitor. There should be a little black piece of plastic that sticks through a slot in the metal plate behind the power inverter. Try pushing this up (might be a reset of some sort) and then plugging things back in.
Anonymous
Level 1:
  • Posted on Sep 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
637
Points
I turn on the computer and the light turns green and it makes the click noise and then a couple seconds later the light turns amber and it makes the click noise again and the screen stays black...
Anonymous
Level 1:
  • Posted on Oct 02, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
637
Points
The problem with the Princeton LCD Monitors is the Power Supply inverter!!! You Can replace this item by going to www.lcdparts.net and locate the model you have with instructions! Hope this helps...
A
Anonymous
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 28, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
728
Points
Before you replace anything  pull the light out and then you can see if they are in good shape, outside of the screen is not too hard but delicated take easy, and check o site of lcd repair I think this is the name.
A
Anonymous
Hi, I have the same problem. You turn it on and it will flash the correct colors and screen shoot for a half of a second then goes black. The green power indicator shows the regular green light as it did when working ok. I turn the computer off and the light turn amber as it should. I plugged it into another computer and same problem. Any help out there before I use it for an anchor on my boat. Thanks...
squiddiddler
Level 1:
  • Posted on Oct 05, 2007
squiddiddler
Contributor
Level 1:
Answers
Questions
0
Helped
637
Points
Looks like one of your backlights is bad, first indication is the red or pink tint, replacement of the lamp is fairly easy. If one lamp is bad the inverter will not work. You can get a replacement lamp from Mouser electronics for about $12
The power supply for my Princeton Monitor, Model VL1916, S/N WCCE4307992 has gone bad. How do I get a replacement?
THe AC adapter (power supply) for my Princeton VL173 went bad. I discovered it was the PS and not the display by plugging in an old adapter from an HP printer that I had replaced. The input plugs matched and the power out profiles were nearly identical Only very minor differences). It was just a stab in the dark, but it works! Now my display is 12 years old and still going strong. I hope this helps.
2answers
My Princeton 19 inch LCD monitor keeps turning off and I have to un-plug it, wait, and plug it back into the wall socket for it to go back on. I replaced the multiple box and the power cord and am using...
bsims77010, Tell me brand name of electrolytic filter capacitors on the large "switch-mode-power-supply / CCFL inverter supply" printed circuit board. Are any of them SWOLLEN on the end that is up ??? You can see typical "failed units if you visit YOUTUBE for video clips that show owners/tech's that replace them with new ones and now have working units again. You must tell me more about this "keeps turning off" thing???? Is unit going to "black screen" only?? Or is it going to "black n blank" screen"??? There is a difference!!! If black only then 5vdc might be ok! If "black n blank then +12vdc & +5vdc sources could be in shut down mode. Do you see screen data with aid of bright flashlight held 1 inch from the "black" screen?? Once you have knowledge of what makes "raw white light" on reverse side of your lcd panel, then you will have clue to how the new screw-in, curlie-Q style CFL light bulbs work and what an "electronic ballast" circuit is. 12fixlouie
Post reply if you need further assistance.
1helpful
I have the princeton VL193 monitor. Its blank, no power light
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Princeton monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
The monitor is only 2 years old. less then 50
If you left it plugged into the outlet, the power supply is still running 24/7 even you never trun it on! Look inside for bad caps first, see example of failed SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
My princeton VL2018W will flash the screen when first powered on but goes blank after. With repeated unpluging, the display used to stay, but no luck
floresa57, After lcd panel "flashes" is the lcd panel "black" or is it both "black" and "blank" when you perform the flashlight test that every LCD owner should know how to do and interpret the results? Do you have warranty? If no, then read more responses in my FIXYA profile for clues on what YOU will or what YOU won't do to fix your BLACK SCREEN monitor!!! Floresa57, the basic principles of design and operation of your Princeton VL2018W are same as all other brands of Fluorescent backlit LCD monitors!!! It can be fixed. READ, READ, before you do anything. Understand the reason WHY your monitor is now black and lifeless. Follow all the LINKS to other web sites so you will be informed and less likely to be overcharged on a repair job that should have cost less than $50. Good luck Floresa57. Rate this on FIXYA if it was of some use to you. 12fixlouie
1helpful
I have a Princeton VL1918 LCD monitor. Need help
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. If you don't see any bad capacitors then the next thing would be bad CFL (backlight tubes) in the screen itself. If it is that then the monitor needs to be replaced because of the tech skills needed to replace then. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
1helpful
2answers
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Monitor turns on then off quickly
From your description of the issue, the LCD and or hte inverter has failed. If less than a year old, contact Princeton Digital for warranty repair, if outside 1 year, it is likely cheaper to replace than repair
2answers
I have a VeiwSonic Monitor model VA712b that went blank.
sell it.. the product and sevice from viewsonic in my opinon sucks nothing but problems tv less then a year old want to ship it back and forth to fix it piece of s**t
Princeton VL1919 repeatedly pops when turned on
If you feel confident take the monitor back cover off and replace the 3 bulged out capacitors
Top Princeton Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
