Same problem here... I don't know how to open it
I also have the same model of mp3 player with the same problem, the screen on mine dosen't work, what you should try is: 1. take back cover off. 2. unscrew circuit board from front cover. 3. try turning it on and hold it to your ear, if you hear beeping noises it can be fixed, if not you're screwed. 4 while it is on, make sure the screen is awake and remove the back cover of the lcd screen. 5. stick the screen into the light, if you see a picture you have a loose wire on the backlight (my problem), if you don't see anything you will need to replace the screen. Hope this helps!!
I'm curious if you bought a new battery because my same model is doing the exact same thing and mine is only 2 1/2 months old
You need to replace the battery. The problem lies with the battery. http://www.cobyparts.com/
