KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
Posted on Sep 27, 2007
Kitchenaid Stainless Microwave Handel KHMS155LSS
Hi. I have the above microwave and the "stainless" looking plastic handle has rubbed off and is now almost white. I am looking for the replacement part but can't seem to find it. But better yet, is there another model that has a real stainless handle that I could somehow adapt to fit mine? The Kenmore Elite handle seems to have about the same measurements? Or maybe a newer model Kitchenaid? I feel another plastic one will just wear again in a year.
  • 1 more comment
  • maya12 Nov 04, 2007
    Hi my handle came off. Handle remains intact. but the white connector has broken off. how do i fix that even if i get the part
  • Anonymous Nov 27, 2007
    Handle is made of plastic and the paint is wearing off and scatches off easy.Found replacement handle at partselect.com but had no instructions for replacing the handle.
  • Anonymous Mar 16, 2014
    I understand the Kitchenaid khms155lss-0 Microvave is discontinued...can you tell me what model replaced it, and are they the same size/dimension?
A
Anonymous
Part number 8184264 should do the trick.
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
I found the real fix to install a new handle on a KitchenAid Kitchenaid KHMS155LSS Microwave...none have been correct until I seen this posting...it works! Use this link to see the...
Here's my standard post on getting into the doors:
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
1helpful
Where can I buy a new handle to my KA KHMS155LSS-0?
A replacement handle can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part numbers are as follows:
8169737 - White
8169738 - Black
8169739 - Bisquit
8184264 - Stainless
When ordering, make sure you use the appropriate part number to match the color you have. All these sites offer competitive pricing, so shop and compare.
If you need assistance in how to replace the door handle, the following link explains how:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
If you have questions, or need additional assistance, please post back and let me know. I hope this helps you.
I have a kichenaid microwave#khms155lss-4 my son put a stainless steel bowl in it and i dosen't work help its only 3 years old
It's most likely a blown magnetron thermostat, but you should also check the fuse and the oven cavity thermostat.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing the thermostats for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Kitchenaid / Whirlpool owner's manuals and installation instructions here.
4helpful
3answers
How do I replace the door handle on a KHMS155LSS Kitchenaid microwave?
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
This should be a very simple repair that you can easily perform yourself.
If you have any questions, please post back and let me know. You can refer to this illustration, if you like, to assist you as well:
http://pcappliancerepair.com/model-display.php
Inneed to replace the door handle. I have the
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and/or replace the door handle:
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER.
If you have any questions, please post back and let me know. If the model number you listed this quesiton under is correct, you can refer to pcappliancerepair.com for some excellent exploded view diagrams of your microwave that confirms how the door is assembled. The part numbers for a new handle (if you haven't purchased one yet) are: 8169737 - (White) 8169738 - (Black) 8169739 - (Biscuit) 8184264 - (Stainless) Make sure you use the correct part number when ordering to ensure you get the correct color to match your appliance. I hope this helps you.
Need installation instructions for replacing door handle on kitchenAid microwave oven model KHMSi55LSS0
Remov fan cover, bottom plate, you can either do it right and pull out the entire plastic baffle to reveal the hindge bolts or you can just jam something between just enough to get a long socket on a small socket wrench. You must replace the entire door. Trying to replace just handle is almost impossible.
2helpful
Kithchenaid Microwave
You'll notice there are small clips holding the stainless outer door to the black metal inner door. Get a bunch of putty knives (butter knives work too) and work a knife into about every other clip. I did it on the bottom. Once you're sure all the bottom clips are free, and you've removed the three screws on the side of the door, you'll be able to gently pull the stainless outer door away from the black inner door and get to the handle screws.
I bent both doors in this process, and tore the black plastic liner into a few pieces while I was getting everything out, so I had to buy a new door ($200). Be careful.
1helpful
Replacing door handle???????
gently pry the plastic from the inside working from the hinges to the corner. you will need to put something in place of the screwdriver when you pull it out to go to the next pry position (about every 2 inches. i use apex bits. you can use anything about the diameter of a cigarette. then the screws for the handle will be exposed . it all snaps back together.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
Marvin
Marvin
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
