Hitachi 53SWX10B 53" Rear Projection Television Logo
Posted on Apr 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Picture jumps on projection tv
Picture jumps like v hold on old tv's. when you bump tv it stops. getting worse?
Grand Canyon Tech
Level 3:
  • Hitachi Master 3,867 Answers
  • Posted on Apr 26, 2009
Grand Canyon Tech
Hitachi Master
Level 3:
Answers
3867
Questions
Helped
1176448
Points
12717
There is not more knobs for V hold so there is a circuit in its place that is going out and needs repaired and it is worth it because these TV are great when they are fixed it will get worse do not bang on it your going to loosen the part that is going out and may cause it to heat up and the list goes on.. take it in you be glad you did if this info helps please rate it fixya thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Hi, this tv is driving me nuts. I just had the bulb replaced because it was jumping and going out. I thought this would solve the problem of the jumping, but is still does. Any ideas on what it could be?...
Tv have jumping picture and go out are not the projection lamp problems."Jumping" Horizontal or Veritical high votage area circuitries have dead parts,must hire a tv tech. to trouble shoot and replaced parts to solved "H" or "V" hold tv to work.Tries many tvs shops,tries get the prices best qoutes and get it repair.
1helpful
The picture on my TS-4573 rear projection tv has started to roll vertically at a fast rate. How can I make this stop. On old tv's there was a vertical hold adjustment on the back that you could play with...
this fault is caused by defective electrolytic capacitors in the vertical deflection circuits, they need to be changed out, do this before it causes more problems, there are no adjustments for this anymore.
Tv picture is jumping
Unfortunately, JVC service manuals are not usually available outside of Authorized service centers. That being said,anyone that services TVs should have seen similar symptoms on other sets and should be able to "fix" this one even without a schematic. Call around. In the meantime, I'll look into this a bit more.
Dan
Lightning strikes on screen and takes awhile to warm up then fine
sorry its not an easy fix at all. im sorry wat you have to hear, but do you have kids? if so, they probably bumped into or hit the screen. that would result in permantly damaging the screen
3answers
Hitachi 60" rear projection, convergence
Check out this document to adjust your Hitachi projection t.v. I did my 11 year old t.v. today.
Hitachi_DCAM_Manual.pdf
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Jumpy / Schrolling Picture...?
this is a problem of synchronization.  are there any adjusting knobs in the tv set (vertical hold adjust) if  yes you can try but if none maybe consult a technician.
Rolling screen
This may be a vertical hold control problem I'm not sure where the Vert. Hold potentiometer is on the mainboard. I would see if you can find someone who can locate it and adjust it.
2answers
Red Horizontal Lines
they gona get worse to dead circuit, a small capacitor (problably in the neck board) is bothering you, get a tech now that he can see the problem, gonna be cheaper now....good luck ps some times the picture say to the tech was going on
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
