Just purchased tv and the quality of the picture is still fuzzy tried to mess around with the resolution but it still isnt very sharp at all
The resolution of the tv doesnt seem very clear at all. The picture seems a bit fuzzy and im sure that this tv is suppose to have better quality. Is there a way to fix this?
Posted by gina2324 on
  • gina2324 Apr 28, 2009
    Well Its a SHARP 32" LCD TV. I know we go through Charter. The tv has regular cable channels along with HD channels. The HD channels are definitely better quality than the basic cable channels. I tried to adjust the sharpness/resolution level on the tv and i seemed to find a decent level for both cable and HD but i just figured that there may be something else causing the tv to not have amazing quality. Our other tv is a 50" plasma which is very sharp so i assume they are not the same type of tv however the 50" just has a better resolution.
  • Anonymous May 11, 2010
    What is the video source you are using a cable or satellite box? Is it high def? The picture will only be as good as the source. Non HD channels such as basic cable will be slightly blurry ,fuzzy and washed out looking regardless of the TV used. Now if you have it on an HD source and using an HD connection such as HDMI or component cable and it still looks fuzzy that could be a problem.
Anonymous
  • 201 Answers
The TVs produce picture using entirely different methods. Usually the colors and especially level of black color are better on plasma, LCD will have some trouble various shades of gray and black especially shading on peoples faces etc.. This is not a defect in the LCD just a limitation in current technology.
Posted on Apr 29, 2009
Poor picture and colour quality on hd through hd box red is pink fuzzy hd picture
You need to check the resolution of your TV thru your input setting, try to check which will give better picture quality between 1080 or 720 settings. Also secure that your input setting as either HDMI 1 or 2 or 3, you can use the original remote and change setting by pressing input in cycle.
Jul 08, 2011 | Televison & Video
How do i change from 480i to 1080i on a sharp 52"
You don't. The TV picture will be fuzzy when watching a program in 480. If you have a lot of video in 480 or 720 you can get an up scaler. They are expensive, but that is the only way you'll ever get a Hi def picture from a low resolution signal
May 28, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
Just bought the Samsung 550 Plasma Hd Tv can you tell me if we just use a regular cable from the wall to the Tv will the picture quality be sort of off.. WE have an HM MI cable from the cable box to the TV...
unfortunately cable does not give you the best quality picture and "fuzziness ' is the reduced resolution being displayed on the tv.
the easy way to check the picture quality is to get a decent hd antenna and scan using it for free hdtv signals, if these are also fuzzy, on all channels then the tv has a problem but if it is only on a few lower resolution channels then its just the way it is until everyone is hd 720 or better.
Jan 31, 2010 | Samsung 50 in. Plasma TV
New vizio 26'' hdtv seems sharp from a distance, but pixalated and
it is important to understand the difference in digital cable and high def. high definision is on a fiber optic display alwing milions of pixels per square inch on your tv. the resolution effects your fuzzy picture you are recieving . the only real way to fix that fuzzy dull picture is to get a HD box from your cable provider and an HDMI cable to conect it to your HD TV. this is the only connection you will need for picture and top line sound. In the end the fee is usually $9.95 or less a month and it is well worth the difference in quality of TV viewing.
Mar 16, 2009 | Vizio VA26L 26 in. LCD HDTV
Logitech Quickcam Chat
Hi Thomas,
Have you tried adjusting your resolution? To maximize the quality of video/picture that your webcam can capture, Turn the resolution into 1.3megapixel. Adjusting the resolution is by clicking the arrow above the Video Option.
Oct 25, 2008 | Logitech Quickcam Chat Webcam
Picture quality
Try cleaning the lense. May have smudged finger prints that cause light diffusion. Cheers
Aug 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
DLP HL-R5067W RESOLUTION
Please provide all part info for verification.....Your model is
HL-R5067W.......Engine # = ? , DMD # = ?.....Possible wrong part installed or bad new parts............T.
Dec 21, 2007 | Samsung DLP HL-P5663W 56" TV
Fuzzy picture with DVI input from NVIDIA PC Card
I have the same TV and I found that increasing the DPI percentage (Dots Per Inch) you could reduce the fuzzy stuff, but in its still no where close to being the same quality as VGA. Hope that helps.
Nov 17, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
