Acer Aspire 5050-3242 Notebook Logo
Posted on Apr 26, 2009
Pioneer DVD-RW DVR-K17RS ATA DEVICE NOT WORKING L CAN OPEN MY CD FILES my device cannot read cd but work with dvd
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Apr 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
776
Points
6
First you need to re install the driver,
do this and try again, if not solved you need to fix the registry, but this can harm your computer,
download tune up utilities and ccleaner,
those programs can help you
  • Anonymous Apr 26, 2009
    first you need to re install the driver,
2helpful
3answers
Pioneer DVR-K17RS ATA ACER CODE=39
Code 39 for cd/dvd drives is a common problem, you need to edit the registry to fix this error. See these instructions on how to fix code 39.
PIONEER DVD-RW DVR-K17RS ATA DEVICE NOT WORKING
If running XP:
First try uninstalling DVD/CD the device using the Device Manager.
Then restart PC and see if all goes well.
If no success go to ms knowledge base
http://support.microsoft.com/kb/314060/en-us
And see what they recommend. I used their tool and that fixed my problem.
HTH :)
1helpful
2answers
it's windows issue, you just need to edit windows registry.
Follow this step from microsoft:
19helpful
6answers
Download driver software for PIONEER DVD-RW DVR-K17LF ATA Device
I wish to download the Software drivers for Pioneer DVD RW
2answers
Hi How old is this laptop? If it is brand new, then you should be able to send it back to acer. Its the problem with drive or mainboard not with the drivers.
Thanks
I have a big problem
Did you install the drivers/software for this drive?
1helpful
3answers
Try to remove the device from Device manager, and then reinstall or upgrade the driver. If the error continues to occur, it may be possible to edit the operating system Registry to resolve the issue.
Click the Start button, press run and type regedit.
  1. In the Registry Editor window, in the left pane, double-click the HKEY_LOCAL_MACHINE folder.
  2. In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
  3. In the System folder, double-click the CurrentControlSet folder.
  4. In the CurrentControlSet folder, double-click the Control folder.
  5. In the Control folder, double-click the Class folder.
  6. In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
  7. In the right pane, click to select the UpperFilters registry value.
  8. Press Del / Delete to remove the registery entry.
  9. In the Confirm Value Delete dialog box, click the Yes button.
  10. In the right pane, click to select the LowerFilters registry value.
  11. Press Del / Delete to remove the registery entry.
  12. In the Confirm Value Delete dialog box, click the Yes button.
  13. close the regedit window.
  14. Restart the computer.
2answers
If you can't restored the driver, you should reload the operating system using Alt+F10 or using disks (not from windows, boot from disks)
In your case, it's look like you can't access the dvd in windows, i hope you can access in dos mode.
3helpful
4answers
Dvd-rw dvr-k17rs ata with aspire 5610z
Hey Google AUTORUNGUI.dll Download It And Then Just Copy The .dll to Your Win System32 Folder Replace It.
SHOULD WORK...........................................
Comment If It Doesnt I Will Tell You Some More Solutions
And Leave Your PC Info With Operating System OtherWise Really Hard ....................................................................................
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
