How can i reformat my bb 8100?plss help
If you are having problems with your Blackberry Pearl 8100, 8110, 8120 or 8130, you might want to wipe all of the data off of it and start fresh. You may want to try resetting the device first by removing the battery from the unit for about 5 seconds and reinserting it. If that doesn’t help things, proceed with these steps to erase all data on the device.
You may want to backup your data before trying these steps.
1. On the Home screen, select Options.
2. Select Security Options.
3. Click General Settings.
4. Press the Menu key.
5. Click Wipe Handheld.
6. Click Continue.
7. Type blackberry.
All the data on your BlackBerry Pearl will then be deleted.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Its simple all you need to do is buy an unlock code from a website like http://blackberryimeiunlockcode.net/ or any other website, on website order your unlock code
by entering your imei number & network which your bb locked to.
You`ll get your unlock code through e-mail with
in few minutes with instructions of entering the unlock code. Just
follow the instructions for entering the code & That`s it your
blackberry has now unlocked & then you can use it with any GSM Sim
card
worldwide.
The Website will give you the blackberry unlock code as cheaper, as well as much faster (within 1 minute)
than a shopkeeper does. Website also gives you a 100% money back
guarantee if the code does not work. This is the best way to get unlock
code for your bb & unlock it from the comfort of your home.
Unlocking through code is permanent means it cannot be re lock again itself!!!
Click here to get blackberry pearl 8100 unlock code
