Question about Microsoft Office Professional 2007 Full Version for PC
Dell 968 printer not responding message please help
Dell 968 printer not responding message,installed drivers and printer software already,i uninstalled the printer software then reinstalled it.and when i go to print something i get something about print filter pipeline stopped working ,and printer not responding,PLEASE HELP I HAVE TO PRINT OUT SOME ESSAYS FOR COLLEGE PLEASE HELP.
Anonymous
  • 122 Answers
Try unplugging the printer and plugging it back in, also do you have the printer set as the default printer
Posted on Apr 26, 2009
Dell 968
Markw501,
Th 968 has no windows 8 drivers/software and is not compatible with windows 8.
Click this link and look for your model number to verify.
http://dell.to/UMzvYJ
V8
Apr 26, 2014 | Dell 968 All-In-One Printer
No scanner
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 18, 2010 | Dell 968w Printer
How to install printer without cd
click on this link and download the driver for your printer. then goto the file you downloaded the driver too and install it to your computer. then if your printer is already hooked up to the computer a message will pop up and say new hardware found dell 968 printer or something of the sort
http://search.dell.com/results.aspx?s=dhs&c=us&l=en&cs=19&k=968+printer+driver&cat=sup&ref=ac
Feb 23, 2010 | Dell 968 All-In-One Printer
Dell AIO printer 968 takes for ever to print a 4 x 6 photo. Any solution? Thanks Rajan
According to the manual a photo can take up to 15 mins to print on that printer. There is no way to speed up a printer.
Jan 09, 2010 | Dell 968 All-In-One Printer
Del 968 aio printer driver is not installed how do i reinstall printer driver
Hi!
You can download free Dell 968 Printer Driver and instal it from the following link---
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 12, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell 968 won't scan, also comes up with ALOC exe problem, please help. Tried re-installing etc but no luck...
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
CF
Jun 25, 2009 | Dell 968 All-In-One Printer
Dell AIO Centre for 968 printer
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
PREM
Apr 06, 2009 | Dell 968 All-In-One Printer
OCR application error with the Dell ALL in ONE
OCR is a software provided by Dell to convert a scanned document to editable text(word) document. If you scan without OCR software, printer will scan it as a Picture and you can not edit it.
Now here is your answer.
When you install Printer CD, it also install OCR software (Abbyy Fine reader) along with it.
You might have uninstalled the printer drivers and reinstalled them by downloading it from Dell support site.
I must tell you that Downloaded drivers from Dell site DOES NOT contain OCR software.
Solution:
1. You can download free trial version(15 days) from Abbyy.com
Click here to download
2. If any of your friend or relative have printer listed below then you can use the same CD to install the OCR software.
List: Dell 924, Dell 926, Dell 928, Dell 944, Dell 946, Dell 948, Dell 964, Dell 966, Dell 968.
location on Disc:
D:\OCR\setup.exe
3. You can scan using MS Paint.
Click on Start > All Programms > Acccessories > Paint
Click on "File" on Top left corner.
Click on "From scanners and cameras"
Click on "Scan"
It should be able to scan.
4. If you want to use Dell All In One Center.
You can disable OCR option for scanning and it will scan as an image.
Open Dell All in one center.
Click on Advanced scan options Under scan,
Uncheck "Use OCR software".
Click OK and try to scan again using Dell All In One center or using the printer operator panel.
Please revert for any further assistance.
Nov 05, 2008 | Dell 924 All-in-One InkJet Printer
Microsoft Office Professional 2007 Full Version for PC Logo
264 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
