1998 Ford Taurus Logo
Posted on Apr 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
...where is the **** cd changer/player in my taurus 1998 lx?
I have the cd button on my radio panel but..no cd slot..help lol?
  • 1 more comment
  • nathalie05 Apr 26, 2009
    when i press cd or change cd its writing < no > ..but when i push tape without a tape in its saying samething ..strange..i looked everywhere in the car/trunk ..
    cool thx so need to go shopin i guess lol.
  • Mike Butler
    Mike Butler May 11, 2010
    Nothing hapens when you push CD button? How about an eject button to push, maybe front flips open? What brand & model player is it?
Anonymous
Level 3:
President:
  • Master 1,263 Answers
  • Posted on Apr 26, 2009
Anonymous
Master
Level 3:
President:
Answers
1263
Questions
Helped
682689
Points
4577
That cd button is for an external changer that you must install yourself. once you install the the changer then all you have to do is press that button and through the circuit you can get your cd music.in order to install the changer you have to purchase a link cable to the the vehicle from the changer. you will not have to cut or splic any wires at all get the connector cable and the changer and once installed your all set. the plug in for the changer is in the trunk of the vehicle. now you will not have access to insert the cds while driving because that is not how the system works in a conventional sense like a cd stereo does
1999 Ford Taurus stereo wiring diagram
These are the three top websites. According to Just Answer it came with AM/FM Radio, AM/FM Radio Cassette, and two types of AM/FM Cassette / CD Changer. All 4 are shown in the link
https://www.justanswer.com/ford/0hkix-find-1999-ford-taurus-stereo-wiring-harness-diagram.html
These are the other two websites.
1999 Ford Taurus Car Stereo Wire Colors and Locations
The12Volt https://www.the12volt.com > installbay > stereodetail
1999 Ford Taurus Stereo Wiring ; Ground, Black/Light Green ; Illumination, Light Blue/Red ; Dimmer, n/a ; Antenna, Left Rear ; Front Speakers, 5" x 7" Doors.
1999 Ford Taurus Radio Wiring Diagram
MODIFIEDLIFE https://www.modifiedlife.com > 1999-ford-taurus-radi...
Our 1999 Ford Taurus radio wiring diagram shows you all the radio wire colors and what they do. Table of Contents. 1999 Ford Taurus Radio Wiring Diagram; 1999 ...
.. Here is the AM/FM Radio wiring
My radio doesn't have a cd but there is a button marked cd. Is it possible there is wiring in the trunk for the cd changer i have?
Usually they don't do that. We have a 1998 Ford Taurus that has the button for the cd but no wiring for a cd changer in the trunk. You can check for yourself if you like.
1helpful
2answers
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
1helpful
I'm looking to do do 2 things with my 99 Taurus LX Sedan...replace the original Stereo with 99 that has a CD player or add Cd changer...which is more practical? Also where is the fuse for Cigerette...
buy a single cd/radio,that way you will not carry hundreds of dollars worth of discs around, also get one where you can plug in your mp3 player in,then you will not need discs, which are now obsolete anyway.
5helpful
3answers
2005 Chevy Malibu Maxx cd changer error
You will need to have the radio reset or checked out at the dealer.Ther could be a cd stuck in it.Or the radio/CD player may have be on when the battery power got to low.
2003 Ford Expositi CD Player will not play or eject
Does the CD door open or is it stuck open? If it is open look to see if you have a jammed CD. This happened to me and this is what I did. A CD had gotten off track and jammed the CD changer turn table. I stuck a little key in the slot and was able to pull the CD out. This fixed my problem. Hope it helps.
2answers
How do you clear a CD changer error code on a 1998 Ford Taurus radio? The radio displays DJ (probably for disc jam). There are no CDs in the changer. I cannot get the CD player to power-up because of the...
You can look in your owners manual, usually there is a little card in there that gives you your radio code to push into the radio, If not you can call your local Ford dealership and give them your VIN number of the car and they can give it to you. also if you wanted to go to the extreme measure you can pull out the radio from the dash and most of the time the code is printed on the radio.
Good Luck I hope this helps.
Twitter, SwiftAuto
swiftautorepairs.com
2answers
Can not find where to plug CD player to the harness
does the radio have cd changer controlls? if so you may find the wires in the trunk if not you will have to buy a harness from ford and make sure the cd changer will work with the stock radio. Call the local ford dealer parts dep but make sure you have the vin number from the car with that they can look up the car and tell you what options where installed from the factory and can order the correct cable
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
