SOURCE: Engine RPM too high when transmission shifts. Bangs into gear.
check your fluid level when the car is warmed up
SOURCE: s10 blazer surges
might wanna check intake gasket for leaks on the high engine rev as for tranny might be in the comp
SOURCE: my 2004 chevy tahoe revs really high shifting into different gear
suggest checking the fluids, may be dirty and need a filter change. mine did the same thing untill i did a service on it
SOURCE: slight miss in engine, hard shift from 1st to 2nd long 2nd gear
Check both O2 sensor(s) and catalytic coverter.. P0420 means catalyst below threshold. Also check the sensor at the transmission and solenoid.
SOURCE: I have a 1999 Chevrolet
have it scanned, probably has a code 1870 (transmission component slipping)
means torgue converter is slipping beyond specs, actual casue is valve body is wore out causing pressure problems
