Question about GE JTP20 Electric Single Oven
Check the door switch. If it is stuck in the closed position the light will remain on. Part number WB24T10147
Posted on Feb 23, 2018
SOURCE: GE built-in 27" convention oven (JKP18)
I have the same oven and the problem is probably the control panel not the circuit breaker. I'm having the panel replaced next week for the 3rd time in 8 years but, you can find it on the web at repairclinic.com for about $140. they also provide troubleshooting help and installation help. I've spoken with GE many times trying to convince them that my oven may have an assembly related problem but they don't want to hear about it. Just replace the part and avoid all the aggravation I've endured trying to get GE to take care of it.
Good luck
Posted on Feb 16, 2008
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
SOURCE: ge monogram single convection wall oven
There is usually a micro switch that is activated when the lock lever is in place - very likely this switch is still activated or has failed closed (defective) .
Posted on Aug 31, 2008
SOURCE: Replacing a 30 inch wall oven -
a number of solutions for your problem a little smaller better then a little larger, iv seen depending on surrounding cabinetry, either wood fill strips, lexan(plastic) strip added as a filler. depending on what the installation guide recommends for opening , that is all that would be required what you fill if with will be a purely asthetic choice
Posted on Nov 13, 2008
SOURCE: GE Elec oven JT952-30" blinks the "lock" after self-clean
Try unplugging power cord or trip circuit breaker, to cut the power to the appliance, then wait one or towo hours for the oven to cool down completely.
If the door stays locked, then there is a fault, probably a faulty temp probe that had blown because of high temperatures generated on self cleaning, or a defective control assembly. In that case you will need to call a technician to take apart the oven and fix the fault.
Enter model number here to find assembly diagrams and parts.
Posted on Jan 02, 2009
Feb 03, 2015 | GE 30" Built-In Single Electric Wall Oven...
May 27, 2012 | GE 30" Built-In Single Electric Wall Oven...
Dec 14, 2011 | Maytag 30" Built-In Single Electric Wall...
Feb 19, 2011 | GE JKP30CMCC 27" Built-in Single Electric...
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
Jan 22, 2010 | GE 30" Built-In Single Electric Wall Oven...
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Sep 19, 2009 | GE Profile 30" Built-In Single Electric...
Jun 07, 2009 | GE Profile 30" Built-In Single Electric...
Jan 12, 2021 | De Dietrich Ovens
107 people viewed this question
