Bad starter, starter solenoid clicks, but the starter does not turn, check the charge of the .... If it still will not start, it means something else is (mechanical or electrical) wrong too.
SOURCE: SIGNAL LIHGTS SCOOTER 50CC QINGQI
i want to but a 50 cc scooter from qunigqi what mods do i have to get the most speed out of it
SOURCE: 1999 ford taurus starter will not engage
Hi and welcome to FixYa,
To my knowledge, you assumption is correct on most designs. That wire should go to the ignition switch and will be hot when key is in START. However, same wire often would be connected first to a relay that is interlocked with some conditions/status other then key to START. They would be:
Good luck and Thank you for using FixYa. Happy Holidays.
SOURCE: starter problem on 1999 chevy P30 step van
yes it can be replaced if you can find the parts. most stores dont sell seperate parts. also check flywheel teeth
hi! there,
well, possible cause engaging starter while
running there is a short circuit on your starting
system wiring.
check on ignition switch after starting and
engine run normally,possibility after
cranking and release the key run
engine normally there is short occurd on
solenoid relay.if defective replace this is
mounted separately from starter motor.
usually on near engine there a fuse and
relay box.
you mention you changed starter motor
and no change,there is starter solenoid
attached directly to starter motor
assembly this to move the plunger pinion
gear that will hook the flywheel to turn.
after cranking and normal engine run.after
that the plunger pinion gear will disengage
by the supply from solenoid relay.so you
must check your solenoid relay circuit.
have a nice day.dont gorget to rate me
thank's
SOURCE: 98 Jeep Grand Cherokee - will not start - starter
I also have a 98 Jeep Cherokee with the same problem. I know I probably need to replace the starter eventually but as of now I turn it to accessory only, pop it in neutral, then start it and it works every time when it wouldn't even try to turn over with it in park. Don't know why it works, but it does. Give it a try.
