Question about Creda Cooktops
Burners ceramic top stove
I have a ceramic top Creda 'solarglow' stove. Two of the burners have stopped working. Do you have an agent in Israel who can help me? If not would it be possible to send instructions for repair and for ordering the necessary parts to a technician who repairs ceramic stoves but does not how to repair Creda stoves?
Posted by David Steinhart on
ray gallant
    Top Expert:
  • Creda Master
  • 68,313 Answers
FIXYA has no agents and have no idea who can assist you there
Posted on Dec 15, 2017
5 Related Answers
Anonymous
  • 750 Answers
SOURCE: crack on glass top stove
Hello
Welcome to Fixya
My name is Huum,
You can replace the smooth top !.
But I will tell you not to spend more than half the price of a new stove. How old is the stove and what's the model number!
Waiting your response.
Please remember to leave a rating before you leave
Posted on Dec 11, 2008
Anonymous
  • 998 Answers
SOURCE: one of the burners won't light.
check all wires to burner and switch. If they are good .....burner burnt out or switch no good.
Posted on Aug 05, 2009
Anonymous
SOURCE: I have a whirlpool drop in ceramic stove and a
When you dont replace the ceramic top that ios cracked could cause issues in your circuit board. The best thing t do is buy a new stove. The parts nad labor along is going to cost you about the same price as a new one.
Posted on Sep 17, 2009
Anonymous
SOURCE: stove top ignition doesn't stop ticking
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
Posted on Jan 04, 2010
paulc118
Paul Collins
  • 15 Answers
SOURCE: Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
Posted on Feb 27, 2010
Why are lights not working under the ceramic JennAir stove top?
You have probably accidentally disconnected some wiring whilst moving it need to re explore
Apr 27, 2014 | Jenn-Air JED8430 Electric Cooktop
Maytag ceramic top stove with the double oven, two small burners don't get hot anymore can I fix myself and how?
It is simple . Before the process make sure the the power is off .. There screws on the back after removing them you can lift the top n easily remove the none working ones . You can buy the spear ones online or local shop . I have done it myself or search YouTube with model number youse come a cross with repair option . Good luck .
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sam_bbe602d2c68da69b
Aug 06, 2013 | Cooktops
Gas ignitor keeps trying to ignite after stove is off.
Hi and welcome to FixYa. I am Kelly. On your cook-top the gas igniters are cycled on and off by a ceramic and copper switch on the front of each of the gas valves. Some of them are in wired Series ...i.e any burner on will cycle all igniters on the cook top and some of them are in Parallel where individual burners are controlled by each gas burner control knob. Inside these tiny ceramic switches there is a flat thin strip of copper that as the gas valve is rotated a cam of the switch actuates pushes the copper strip against the fixed contact. Those little strips over time either break or get bent and stay against the fixed contact. Hence you have and igniter on when the burner control is off. The only fix is to find out which little ceramic switch on the front of the gas valve is stuck. You do it with an Ohm meter POWER off. They all should read open with the burner controls off. The one that reads continuity across the 2 wires is the bad switch.
Thanks for Choosing FixYa.
Kelly
Sep 13, 2010 | GE Cooktops
Whrlpool Electric Stove Top Burners
this is a ceramic top i am guessing.
this is normal, it isthe way it is designed.
it does this so that it does not cause a heat fracture to the glass.. it will continue to turn on and off.. but if you put a pot of cold water on it you will find that this will happen alot less frequently.
Oct 09, 2009 | Cooktops
One of the burners won't light. The stove top is ceramic electric. It is a Magic Chef oven. Other three burners work.
Aug 05, 2009 | Cooktops
I have a whirlpool drop in ceramic stove and a burner isnt working. i had a repair man come and he was trying to pry the stove up but was having trouble because the person that insatlled it years ago...
Apr 25, 2009 | Stoves 23 in. Premier TC600I Electric...
Stove top ignition doesn't stop ticking
Mar 22, 2009 | Creda Colonial 42352 23 in. Electric...
Creda gas cook top sparks but does not light
I have a Creda GGH102 gas cooktop that once power is supplied to it, it will not stop clicking.
Jan 13, 2009 | Cooktops
Gas stovetop burner - continuous clicking
WHEN CLEANING YOUR BURNERS YOU HAVE PROBABLY MOVED THE IRON TOPS-READJUST AND YOU WILL FIND THE CLICKING WILL STOP.
Sep 18, 2008 | Cooktops
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 | Cooktops
Cooktops Logo
162 people viewed this question
Top Creda Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Creda Cooktop Expert? Answer questions, earn points and help others
