Inter-Tel Axxess Corded Phone Logo
Posted on Sep 27, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Inter-Tel Axxes phone outside calls don't go to voice mail
When a call comes in from an outside line, the call goes to the receptionist rather than to her voice mail box. If someone from another extension calls her, the call goes to voice mail. I've reset her phone back to default, deleted voice mail and re-created an associated mailbox, and outside calls coming to that ext. # still go to the receptionist rather than to her voicemail box.
  • spenny123 Oct 02, 2007
    Sorry, wasn't real clear. Thanks for your response, this is only one ext number that does this. All other calls route properly to the ext. #, then to voice mail, unless the caller presses 0, then it goes to the receptionist. And that's how we want all calls to work.
    But this one ext # does not go to voice mail. It calls the receptionist instead and she has to re-route the call the the ext.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2743
Points
I had this same challenge with an InterTel 5000 system. Outside calls going right to the receptionist. My solution: You cannot fix this from a phone, you must open the DB Session Manager, move to Call Routing Tables (this is right above Voice Processor) and move all of your extensions above the "NO MATCH" and "EMPTY" lines on the bottom. Anything below those two lines will bypass the extension and go straight to the main attendant. At least in my configuration it does. See below...
Inter-Tel Axxes phone outside calls don't go to vo - bb752dc.jpg By just moving that last extension "5059" above the "NO MATCH" line, calls will now go to the extension from an outside caller. The trick is to hold your mouse on the pen icon and click several times to activate that line, then you can drag it to where you want. See below...
Inter-Tel Axxes phone outside calls don't go to vo - 8e5e1dd.jpgmg src="/uploads/images/8e5e1dd.jpg" alt="8e5e1dd.jpg" class="h_mi" /> Hope this helps someone?
vandata1
Anonymous
Level 1:
New Friend:
  • Posted on Nov 19, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2743
Points
You need to go to the application for that number / digit translation/ Change the "time out" line to "transfer to extension" then the 4 digit extension in the field to the right (make sure you don't put the application # in that field or your voice mail server will loop and hang then crash)
Anonymous
Level 2:
Novelist:
  • Expert 201 Answers
  • Posted on Sep 28, 2007
Anonymous
Expert
Level 2:
Novelist:
Answers
201
Questions
Helped
142320
Points
224
The phone system handles where phone calls are sent not the voice mail. Deleting the mailbox will not change the rules programmed into the system. This can get kind of complicated for people that do not handle this a lot. There are many variables involved and the rules change depending on if the phone is in DND mode, if the system is in day or night mode etc.. Not sure why you would want ALL calls to the receptionist to go to a mailbox. Do you make your own major system program changes or pay a local installation company to do this?
  • Anonymous Oct 02, 2007
    Each phone has it's own program for what to do if the phone is not answered in a specific amount of rings. Sounds like this phone is sent to ext 100 instead of the voice mail. It would need to be changed in system programming through a computer with the correct programming software for your phone system's version. It's an annoying tactic to make sure you use an authorized Intertel dealer to make any major changes.
    If the phone in question does not ring at all and goes right to the receptionist, it may be set to forward all calls to ext 100. The display should say something to that effect "FRWD:100" or such. If it's not a display phone, borrow one from another location and plug it in there.
Calls dont go to voicemail
The "Recall" Destination of that phone needs to be voicemail. Usually 2500. You have to go inti database programming to make that happen.
I want to know if I can set up individual voice mail b oxes for each of the 9 extensions I have associated with this phone? Details: Callers call in to main line and speak to receptionist. The caller...
What phone system is the 7130 attached to? Panasonic makes a TVA voice mail system that interfaces to a TA-624 or higher model that will give you individual mailboxes and a means to transfer calls to them.
Street price of a new TVA-50 is in the $600 range, but you can find an older TVS50 for less.
Carl
When conferencing two outside parties, how can I (from the Inter-Tel Phone at the office) have myself removed permanently? When I drop off the line and leave the two people on, it rings me back to where I...
The Inter-Tel will not allow you to leave the conference without disconnecting the outside parties, this is the system design. The hold recall time could possibly be increased to reduce the aggravation.
2answers
How do I set phone to ring at my extention?
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
4helpful
Ringer/ Voicemail Bounceback
Well, this one is kinda tricky. If the receptionist knows there's no one there, they can use VoiceMail Transfer.
From the phone, the user can set CF Busy or CF Busy/No Answer with the following codes on the intercom:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding2.gif (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
The last piece of the puzzle is the timing. That's *713 (00-99). Start with 24 (4 rings) and go from there. If it hits the receptionist before the forward takes place, you probably have to adjust the recall timer for call transfer, a system program.
Carl
6helpful
Voice mail not working
When someone is calling my direct line, the phone never goes into my voicemail. How do I fix this?
3helpful
Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
Inter-tel ECX 1000
You definitely can do this with a ECX feature set if you program the lines on the keys. You've got to program "Button Hopping" off in the system this automatically puts the first call on system hold when you press the line key for the second incoming call.
I don't think there's a limit to how many you can have on hold.
Top Inter-Tel Lands Phones Experts
k24674
Are you an Inter-Tel Lands Phone Expert? Answer questions, earn points and help others
