Question about Uniden DECT 6.0 Cordless Phone ID
Cant register/install a new dect 6.0 uniden 2060 phone
I just got dect 6.0 uniden 2060-2 phone. i have fully charged the phone using base. on screen phone is showing "searching" text and everytime i try to go thro' menu->register base, it tries for few minutes and shows message "registration failed". what am i missing? the manual is useless. thanks much in advance
Posted by kddesai98 on
  • 2 more comments
  • Anonymous May 21, 2009
    3 handsets all say connection unavailable. Waterproof set says to register but how? The manual is useless.
  • Anonymous Mar 16, 2014
    WHEN TALKING ON PHONE IT ECHOES WITH YOUR voice HAVE 2 more uniden dect6.0 in other rooms dont do it
  • Anonymous Mar 29, 2014
    how do i get my messages from another phone
    how do i take my messages from another phone
Anonymous
  • 3 Answers
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
  • 1 more comment
  • Patty Dietmeyer Hook Aug 17, 2013
    This was SO HELPFUL! I checked a zillion other places, but only your explanation worked perfectly. Thanks so much!
  • Pepper Derr Sep 02, 2013
    Same here. This should be posted all over the internet! De-registering and then re-registgering worked like a charm. Thanks.
  • Anonymous Oct 25, 2018
    I had the same problem in that no matter what I did the phones would not register. On a whim, I took the battery out of the older phone I was disposing of, clicked it in new phone, let it charge just a couple minutes, and it registered right away! CHECK THE BATTERY if all else fails!
Anonymous
When you select register on the base, you need to press and hold # on the phone... the instructions below worked for me, finally, to get the stupid waterproof handset registered. whew!
Registering the Handset
If you have purchased this accessory handset separately, it must
be registered to the base before you can use it.
Notes:
• The handset must be fully charged before attempting to register.
• Only one handset can be registered at a time.
1) If the other base has an LCD display:
• With the phone in standby, press [Menu/Select] on the base. Press [down] to move the cursor to REGISTER HANDSET and then press [Menu/Select]. HANDSET
REGISTERING appears.
If the other base does not have an LCD display:
• Disconnect the base AC adapter. Then press and hold
[find hs] or [find] while you reconnect the adapter. Keep
pressing [find hs] or [find] until the charge/in use LED
starts to blink.
2) On the handset, press and hold [#] until the handset beeps and displays HANDSET REGISTERING.
3) When the handset finishes registering, it shows REGISTRATION COMPLETE in the display.
Posted on Jul 20, 2009
  • optimusplus Aug 01, 2011
    Thanks for the solutions posted. I've tried all the suggestions but the only one that worked for my phone is the one disconnecting the AC adapter of the base and pressing & holding the [FIND] on the base while reconnecting the AC adapter. The handset was successfully registered after placing it to the base.
Anonymous
The above solution worked for me. For some reason after removing the battery, pressing * and # together, replacing the battery, and then trying to program register the phone, it actually worked.
Posted on Jul 17, 2009
Cory Hammer
    New Friend:
For me I needed to pull the power from the base, hold the find button while reconnecting power, then put the handset in the cradle. I had to repeat this for each handset that I was adding.
Posted on Jun 07, 2013
I cant dial out it says register HS i am not familiar with the procedure.
When you reset a handset (or if you buy a new one1, that handset displays a Handset Not Registered message. If you see this message on a handset, you need to register it to a base before you can use it.
Registering a handset
Does the handset fit in the base cradle?
Yes
No
Place the handset in the base.
The display should say Handset Registering.
1. On the base, open the menu and select Register Handset. The display should say Handset Registering.
2. On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
In about 30 seconds, the handset display should say Registration Complete. Press TALK ( )/FLASh and make sure you get a dial tone. page29image32024
27
If...
Try...
- you don't hear a dial tone- the display says Registration Failed
Making sure the handset is fully charged, then start over at step 1.
To register a handset to a different base, see the section "Expanding Your phone" in the user's guide for the other base.
Uniden dect 6-0 says its out of range but its by the base
Make sure the handset is registered to the base. Since you didn't specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
28helpful
2answers
I have Uniden DECT1480-3. I purchased two expandable handsets, but I cannot figure out how to get the new handsets to register with the base unit.
Up to 6 handsets can be registered with the DECT 1480 phones. I have the 5 phone unit and needed to add the 6th phone. All I got was "Searching" in the display and the battery wouldn't even charge!
So here's what you have to do to get additional phones (up to 6 units) to work with the base. If you can get past step 1, it's a snap...
Step 1: Place a charged battery in the handset. This could be a problem if all your handsets are not registered, since unregistered phones don't charge (who thought of that design?). What I did was SWAP the battery from an already registered and charged phone with the new unregistered phone.
Step 2: Here's where the magic happens. Press the 'END' and '#' keys simultaneously... hold them down until a System Reset menu appears. Select "Deregister HS" and press Menu.
Step 3: Now, do the same thing again (hold down END and #), but this time select Base Unavailable and press Menu. You will see Base Unavailable Yes/No... Select Yes. Then place the handset in the base, wait a few seconds, and Voila!. it's registered. You can even change handset numbers using this menu if you play around with it.
Thank you, helpful employee at Costco for supplying the magic code. And hey there, UNIDEN... including this in the operation manual would have saved many customers much grief with de-registered phones!
Enjoy!
Uniden 2080
I have same problem
2helpful
I have a Uniden DECT 6.0 phone set. I damaged one
1.
2.
DSL filterTelephone cordTelephone wall jack
45
In about 30 seconds, the handset display should say Registration Complete. Press Talk/fl ash and make sure you get a dial tone.
If...
Try...
the display says Registration Failed --
After 6 weeks, phone is dead
still warrentty time so contact ur uniden cordless phone dealer
1helpful
How do I remove the Searching display from my Uniden 2080 DECT 6.o?
I also looked at your manual. If the handsets are registered to your old base, you need to deregister them from looking for the old base. Then you need to register them to the new base. Hope thsis helps!
4helpful
3answers
Uniden dect6.0 handsets do not operate
I am writing for my Mum, who is 99. We live far apart, so it is a bit difficult to fix her problem. She had a new Uniden DECT 60 (?) installed in early July. It seemed to be working fine when we left her, but she says it only rings twice before going to voice mail. She says it has always been like that. How can we fix this for her even though we live at a distance?.
Uniden DECT 6.0 Cordless Phone ID Logo
Top Uniden Lands Phones Experts
k24674
Ekse
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
