Question about Cobra 148 GTL 120-Channels Base CB Radio
Have a new cobra 148 gtl took out of box no transmit or recieve
Radio has no transmit or recieve and is brand new don't see any obvious reason by looking on inside of radio. I know the 148 sound tracker had problems like that new but can't remember what the cause was. this is the gtl any ideas would be appreciated lost the reciept thanks in advance
Posted by tr4903 on
  • Don Reiman May 11, 2010
    Does the TX light work?
    Does it swing?
    Have you tried another mic?
Anonymous
  • 36 Answers
Make sure that your [swr] hadn't changed or went higher than a 1.5, anything higher will interfere with your tranmitting an recieving. other than that with out being there to see an hear your radio this would be the first place to start.
Posted on May 05, 2009
Good day I have an cobra 148 Gtl tx and rx a working but no out put
It might not seem obvious but on many, if not all, current CB radios have separate wires coming from the microphone for RX and TX. It seems like the mic wire for TRANSMIT may be open. It is a common failure.
Feb 28, 2015 | Cobra 148GTL
Uniden tech help
I have a a uniden teddy r that won't recieve.
Jan 01, 2014 | Cobra 148 GTL 120-Channels Base CB Radio
NEEDLE IS TO LOOSE TRANSMIT AND RECIEVE
turn the SWR/CAL/S-RF switch and set it back to S-RF
Nov 17, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl d has problem transmiting with covers off. trying to tune radio up. was thinking I need to ground the chasis
I would say a bad or cold solder joint on board somewhere. Bad quality control. Might flex radio chassis slightly while keying? A tooth pick and hours of probing around switching area on board and the pa section till problem found.
Oct 25, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl-st wont transmit but receives great
Check first your microphone
• check if TX is engaging when PTT is pushed.
• check for continuity ( mic and cable )
If you have not done these steps,
try it first, or borrow other compatible mic for Cobra 148GTL
from your friends on air.
Jul 28, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
I have a new cobra 148 with ssb, about 6 months old, while i was away there was a storm, now the radio doesnt work , recieve or transmit, i also have a cobra 29 ltd that wont transmit but it will recieve....
make sure the mic is good. If for some reason the mic went bad, it will not receive or transmit.
As for the one with no receive, it most likely needs a new final.
If lightning hit your antron, it would be in pieces.
Aug 02, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl b no recieve
make sure that the rf gain is turned up all the way.Check diodes D-12&D-13.
Jan 08, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl new model
Hello bluzfan, Do you remember the old 40 channel CBs? they used basic A3A transmission (dual sideband single carrier)remember how you got crosstalk sometimes, if your power was too high? Then they went to 80 channel CBs (using a single side band as Lower Side Band (lsb) and the other as the upper side band (usb))? more crosstalk but they invented anl (automatic noise limiter)circuitry to compensate. Now you have the 120 channel CB which uses a form of side band multiplexing (20QAM) to generate 3 times more channel density 40 X 3 = 120. Here is my problem; Cobra should not have done this because you will have massive crosstalk and unaudible sounds because of the increase in channels but not an increase in initial (physical)bandwidth. I hate to tell you this but the only cure for the is to use it in 40 channel or 80 channel mode forget the 120 channel mode, or get a radio with better channel separation.
Oct 07, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl
Open the radio up and find the L22 Can/Pot. It's the one with the wire soldered on top. With both fine and coarse Claifier/Voice Locks in the 12 O'Clock positions, confirm, then listen for someone that is on the correct frequency and turn this pot (small ferrite core inside) with a small plastic preferred screwdriver, until they sound clear. Do this for USB as well except, the Can/Pot is L59. Don't adjust the VR5 (transmit) unless you need to.
Oct 06, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
239 people viewed this question
Top Cobra Radio Communications Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
