Question about Lenovo ThinkPad X200 Tablet PC (TopSeller) - Intel Core 2 Duo SL9600 2.13GHz - 12.1 WXGA - 2GB DDR3 ... (744945U) PC Notebook
Owner doesn't know the passwords. At power on, it has two icons, 1 is on top of a can like icon, and the other is a padlock. Because I don't know the password, I hit the F1 after I power on and the thinkpad log appears. I saw two errors 271 and 182 bad CRC2. Is there hope of restoring this thinkpad to working condition or should I dump it?
Posted by Terez on
NOEL
    Top Expert:
  • Lenovo Master
  • 8,546 Answers
This is not to say for you to try it.if you dont no what you are doing please do not try this get some one that does know how to do it.
if you do try this then do so at your own risk.
Turn off laptop, remove battery. Remove palmrest, and remove keyboard (leave keyboard plugged in). Remove CMOS battery, and boot up the laptop without CMOS battery. Your Power-on password is now removed, put it all back together and enjoy!7 Feb 2012
How to Remove and Reset the Power-On Password for a Thinkpad ...
https://www.youtube.com/watch?v=3HRjUK1IB84..
or go to this link and have a good read up about what else you could try first. password power on lenovo Google Search
Posted on Oct 21, 2017
5 Related Answers
Anonymous
  • 60 Answers
SOURCE: cannot get my laptop to the screen to enter password
Try to restart your laptop, when you see the IBM Thinkpad logo press F8 several times until it gives you a black screen menu with some option. Try the "use last known good configuration" first and see if it works, otherwise try to access in safe mode. Once you're in, try a system restore, and bring the computer back to a date you think it should work.
To access System restore you go unser start - programs - accessories - system tools.
Good luck
Posted on Mar 31, 2009
drifterK
Catalin Turcu
  • 4924 Answers
SOURCE: restoring to factor
its virtual impossible the only thing you can do is to reinstall the windows...if you do not want to have drivers problems ..do not format the partition ...just reinstall the os in the same folder....you might also try do blank to default the bios...by removing the bios battery for a second.... some say this might work ...but the sure solution is reinstalling the operating system...
Posted on Apr 06, 2009
Anonymous
  • 117 Answers
try booting into safe mode first F8, see what that gives you. if that fails load your original boot disk if you have vista os. load that disk and select repair to see if you have any issues. once your inside. i recommend using a command to repair any files that may be corrupt or changed. so once you get in go to start, select run and type cmd.exe once the black screen comes up type in sfc /scannow you will need to have the original os disk inside the drive. this command will go through and search any system files that have been changed. let me know if that helps or you need any other assistance
good luck!
ruben
Posted on Jul 13, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: lenovo thinkpad R51e ,when i power on the laptop it show error271
This error message is generated when the BIOS Date and Time is incorrect. Go into the BIOS configuration to change the Date and Time. When you reboot and still get the same error message then the BIOS battery is flat and needs to be replaced and the Date and Time setting needs to be change to the current Date and Time after replacing the battery.
If you cannot get into the BIOS configuration (press F1 on bootup) or you get a lock icon in the top LH corner of the screen, this is a Power on Password symbol, enter the passsword to bootup the laptop and then press F1 to get into the BIOS configuration.
Posted on Aug 10, 2009
Anonymous
SOURCE: I have brought a Lenovo Thinkpad and it has padlock on top left.
black screen with a small padlock in the top left
Posted on Oct 08, 2010
How do I unlock the screen rotation
if you use iOS 7 or 8, swipe up from the bottom to bring up the menu. ON the top row of icons, on the farthest right there is an icon with a lock surrounded by a circular line and arrow. Tap this to toggle the rotation lock on and off.
Feb 24, 2015 | Apple iPhone 5c
How do I unlock my ipad 4?
The term "unlocking" when it comes to iPad means either having a password to access the device, or a process to access and change the underlying operating system. The padlock icon doesn't have anything to do with WiFi. Also, if you cannot connect to WiFi, you cannot get to Facebook, Google, or anywhere else on the Internet, in the same way that if you car wont' start, you can't go to work or your buddy's house. Your root problem isn't that your car won't go to your friend's house, it's that it won't start. SO, please re-ask the question with specifics of your root problem, which is you can't connect to WiFi. Do you know the password for your WiFi router? Can you see it listed in the wireless networks? Do you not know how to connect to WiFi in the first place?
Sep 13, 2014 | Apple iPad Wi-Fi + 3G - Tablet - iOS 4 -...
Padlock icon?
The padlock icon is used to indicate on the browser that the SSL protocol is in use.
It requires the web site to set it up, not you.
May 27, 2014 | Acer Aspire Computers & Internet
I have strong wifi strength but no connection
It sounds like you're in range of a wifi signal, but haven't chosen which network you want your tablet to jump onto. Head over to your settings panel (swipe down from the top, then tap the little cog icon). From settings, make sure you're in the "Wireless and network" tab. Make sure your wifi is turned on (with the green bar below it). To the right, there should be a list of wifi networks you can join. If there's one that has a little padlock icon on it, it means it requires a password (are you at a restaurant or friend's house? - ask them for the wifi password). If it doesn't have the padlock, it's an open network. Does this help?
Best of luck.
Feb 09, 2014 | Samsung Galaxy Tab Tablet PC
How do I change my Facebook password
Hi, please follow these steps to change your Facebook password:
1. Logon to Facebook with your email and current password
2. At the top near the right corner, Click on the Gear icon next to the padlock
3. Click Account Settings
4. Under General Account Settings, Click Edit next to password
5. Enter your current password and then your new password
6. Retype your new password
7. Click Save changes
That's it, have a great day
Dec 03, 2013 | Computers & Internet
Owner doesn't know the passwords. At power on, it has two icons, 1 is on top of a can like icon, and the other is a padlock. Because I don't know the password, I hit the F1 after I power on and the...
hi,
Thinkpad has a very powerful protection, and entering or trying to enter or access it multiple times will cause it to lock completely, and you will need to change the system board - in other words : you need a new heart or brain for it
because the code you post is for the EEPROM checksum is not correct
so, dumping it might be a solution if you don't have anything important to back up, and even if you did, Very hard to retrieve
hope this helps
thanks
Oct 19, 2013 | Tablets & eReaders
DD24DCB6 top drow not working no power
When you say no power, does this mean no function and no lights also? Is there an Icon in the window of that drawer, top right (like a padlock icon)? If so your unit is locked, push and hold the lock button for 3-5 seconds to release.
If not get back to me so we can sort this out.
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 08, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
What do; the four little lights below my keyboard mean? One is the battery, one is the internet, but the other two? Especially the third from the lert with the icon that looks like a stack of pancakes?
The icon that looks like a stack of pancakes is the one for the hard disk drive and the indicator with the icon flickers or lights whenever there is hard disk activity. The reading / writing of large files will cause the hard disk drive activity indicator to light almost steadily until the file reads / writes have completed. There are two icons that look like little padlocks. One has the character 1 and the other has letter A. The padlock icon with the 1 in the middle is the indicator for NumLk or Numeric Keypad lock. Pressing the Fn key and the key with NumLk on it turns the Numeric Keypad on and off. When it is on, pressing the keys for UIOJKL will enter 456123 facilitating entry of numbers with the keys arranged as a keypad along with the top row of keys 789. Finally, the padlock icon with the A in the middle is the Caps Lock indicator which lights when the Caps Lock key is pressed allowing subsequent presses of letter keys to be capitals without having to press the shift key. Pressing Caps Lock a second time turns off the Caps Lock. Similarly, a second press of Fn and NumLk turns off the NumLk.
Mar 30, 2011 | Acer Aspire One PC Notebook
Wi fi passwords
Sad to say, there are no default passwords for wifi except for 12345 or 00000. It is because wifi passwords are unique to the owner of the wireless router. It is up to the discretion of the owner to put a password as he sees fit. Your best bet is to look for an open wifi connection, the one without the padlock icon and hopefully you will be able to connect to it. Good luck!
Dec 19, 2010 | Cell Phones
Laptop is locked out
just learn to play it's fine
Oct 20, 2008 | IBM ThinkPad T21 Notebook
Lenovo ThinkPad X200 Tablet PC (TopSeller) - Intel Core 2 Duo SL9600 2.13GHz - 12.1 WXGA - 2GB DDR3 ... (744945U) PC Notebook Logo
61 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
