Air Purifiers Logo
Question about Air Purifiers
I have the Renewaire Energy Recovery ventilator system, Model EV130, installed in my house but do not know how to set it to the proper setting. The runtime numbers go from 10 to 100 and I am not sure what setting to put it on according to the weather. Any assistance would be appreciated.
Posted by lowridingeor on
Anonymous
The RenewAire system is sized per ASHRAE 62-1999, residential air exchange of .35 air changes per hour, or 8 air changes per day. You can find an operation sheet for the PTL @ www.renewaire.com, downloads, residential, controls, PTL. A chart shows a starting point of ventilation based on the square footage x 8 foot ceiling height with a run time percentage for each model. For 2250 square feet with 8 foot ceilings, the run time for an EV130 is 85%, cycling hourly.
Actual run time will vary by tightness of house, number of occupants, lifestyle (number and frequency of pollutant generating activities). Outside weather conditions should have little effect on run time percentage. I run my system @ 50% year round, when the windows are shut.
The ERV tempers humidity and temperature extremes of the ventilation air year round. It is not a substitute for heating or A/C; it does not dehumidify the house in summer (it does reject some of the incoming summer humidity content, when the net humidity is greater outside than inside). It will lower humidity of the house in winter, or whenever the net humidity outside is lower than inside.
It will ventilate the house in an energy efficient manner all year long. Based on this information, choose a setting and manage the amount of run time to achieve your best IAQ.
Posted on Jun 25, 2009
New a/c - furnace installed, no instruction manual, it is 23 degrees outside, and I have no idea how to turn on heat instead of a/c. Need thermostat instructions.
Usually just put the thermostat fan on auto, the a/c heat switch to heat and set the temperature where you want it. If it's a gas furnace, you will need to light the pilot. Usually instructions are on the furnace door, maybe inside furnace door.
We are using a living air purifier xL15S and we are all getting sick. Headaches, colds. I know on the back of the machine it states that high levels of ozone can be injurious to ones health if not in a...
I would doubt that high ozone levels are causeing your problems. It is possible if your house is not properly ventilated for ozone to be hazardous so I would recommend that you cut the time that you are using your air purifier in half and for the next 2-3 months I would change furnace filters on a weekly basis.Also clean all carpets and drapes to remove all tobaco residue. I hope this helps you and that you all start feeling better.Thank you.
4helpful
2answers
I have an Oreck air purifier model (air 4000). The power light is on but the fan will not turn unless I put it on high speed and manually push the fan to give it a jump start for it to start running but...
I tried that solution and it did not work due to the worn bushing. I went on line to CSH incorporated and ordered #534 Open Ventilation Fan & Blower Duty motor. The motor is a ball bearing motor rather than bushing, and is an exact replacement for the Fasco motor on the original. The repair is easy and a cheap repair at cost of about $67 dollars for the motor plus shipping. The unit now works great again.
Robert
I have cleaned my unit but the red light stays on
Likely so these units usually put out ozone into the air in your home which is a known lung irritant. If you truly have indoor air quality issues the only way to properly attack it is through three steps
source control - what's causing it(uv lights to kill it usually)
ventilation - bring in fresh outdoor air and exhaust stale indoor air(ERVs and HRVs depending on your climate some dealers won't sell these if they don't offer it to you they are dumb find someone who does they are Recovery Ventilators)
filtration - a whole home filtration system (look to dealers who carry Lennox who is the only company with a 100% ozone free product line and the highest filtration rates available on the market "MERV 16" filters or Trane is ok as well as Carrier systems)
2helpful
Have missed placed my manual need to know how to clean. Now that I have taken it apart I cannot get it back together! Help!
These units usually put out ozone into the air in your home which is a known lung irritant. Sometimes they will call it an ionizer or something like that. If you truly have indoor air quality issues the only way to properly attack it is through three steps
You can look up the Lennox Merv 16 filter it was rated #1 in Consumer Reports december 2007 as the best whole home air filter above the trane clean effects and others. can be bought and installed for around 400 bucks to 1000 dependeing on how hard it is and ask about the pure air system if you want higher levels.
3helpful
My ionic breeze doesnt seem to blow any air at all cleaning light stays off Is this normal?
best best is to unplug the unit, and clean the blades completely with a damp cloth, then wait a few for the blades to dry and put them back in the unit. usually cleaning these every 2 to 3 weeks and they should be kept clean to be effective at removing the contaminants in the air. theirs alot of controversy over thease untis thease day's butthey do fuction properly if kept in top condition. also note that the blades must be properly seated in the houseing to work. safty feature that if bumped or knocked down it will cause the system to mostlikly stop working till you pull the blades out and put them back inj. i observed this myself with a model and they are failry good quality but a pain to clean. good luck with it.
4helpful
3answers
Ionic Breeze Repair
Ionic Breeze GP. Unit was working. Removed insert to clean. Now the unit will not turn on.
2answers
I have a Living Air Purifier - Model Flair with Ecotech
You can download the manual online at http://www.ecoquestonline.net/ownersmanuals_web/flair_om.pdf
Basically let your nose be your guide. When you are right in front of the machine you can smell the fresh air. As soon as you walk in the house you should smell that fresh air smell for about 30 seconds and then it should go to the back of your senses. If not the setting on the machine is too high. Dial it back a notch and wait 24 hours before making another adjustment, until you have the right setting.
Hope this helps!
Eric
Open Questions:
Top Air Purifiers Experts
ray gallant
Tom Chichester
Are you an Air Purifier Expert? Answer questions, earn points and help others
