Question about Motorola Talkabout T5420 (14 Channels) 2-Way Radio
I have a set of motorola fv700 talkabout radios. they wont transmit to each other. i checked the inter. elim. code. they are the same. and i have even turned them off. these are new radios. i know they work because i can turn on a different set and brand of radios to "scan" and i can use the motorlas to talk nd listen. the motorolas dont seem to work with each other, please help
eradiostore
  • Motorola Master
  • 1,658 Answers
Take the radios back to a very basic setting with all special features turned off. If the radios have a Qt filter check to see it is turned off, and set your Code to zero (off) on both units. Also, check to see your battery is good in both units. Trade the battery with a known good radio to see if the problem moves to the other radio, is a simple test.
Posted on Sep 10, 2017
5 Related Answers
Anonymous
SOURCE: Talkabout Motorola T5530
I found the T5000 manual here (It covers the T5000, T5500, T5530 and T5550)
http://www.giantintl.com/RadioPDFs/manuals/T5000.pdf
Semper Fi,
Jstwhln
Posted on Aug 18, 2008
eradiostore
eradiostore
  • 1658 Answers
SOURCE: Motorola talkabout 200
Here is a link to the TA280 manual, which is similar to the TA200, http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T280_User_Manual.pdf
Funny thing, I haven't found the TA200 manual in English. Here it is in Czech: http://www.cbradio.cz/doc/Motorola/PMR%20TA200/manual.pdf If you do a google search, you can find the page and have it translated. I'll keep looking, and if I find it in English, I'll repost.
Posted on Nov 10, 2008
eradiostore
eradiostore
  • 1658 Answers
SOURCE: MOTOROLA TALKABOUT TWO WAY RADIOS WONT TRANSMITT- BOTH CAOME ON
Here is the manual for the T5720. It may be very similar to the model you have.
http://lib.store.yahoo.net/lib/starbattery/T56XXusersguide.pdf
Posted on Nov 20, 2008
eradiostore
eradiostore
  • 1658 Answers
SOURCE: how to set interference eliminator code on motorola two way radio
The FV300 does not have the interference eliminator code feature. (Sorry)
Posted on Jun 30, 2009
Anonymous
  • 123 Answers
SOURCE: Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Posted on Feb 04, 2010
Testimonial: "Thanks for the response. appreciated it. It is very useful."
How do you reset the Talkabout FV700 Two-Way radios?
It is best to contact Motorola Solutions.
http://www.Motorola solutions.com/support
Mark
Motorola Mobility Support
Aug 16, 2014 | Motorola Fv750Rcamo 18-Mile 22-Channel...
Doesn't transmit
Check your battery. Transmitting takes more energy than receiving. Also, check your frequency and code settings. The radio you are using this one with might have a different code setting than yours. http://shop.giantintl.com/Manuals.asp
Feb 13, 2014 | Motorola Talkabout T5720 (7 Channels)...
I can transmit to one talkabout but the other person can't transmit to me
Check your programming, it sounds like your Code is not set the same between the two radios. Here is a link to the user guide http://shop.giantintl.com/Manuals.asp Choose your model from the page or the pulldown.
Feb 01, 2014 | Motorola TalkAbout T5000 2-Way Radio
I have a pair of talkabouts fv700's they will receive but I cannot transmit
Check the programming of your frequency, interference eliminator code and Qt filter (if any). Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/FV700%20FINAL%20-%20%20All%20Rights%20Reserved%20and%20call%20center%20email%2004-24-07.pdf
For basic operation turn off any special features, and set the code to zero (off) and the Qt filter (if any) to zero (off). This would allow you to test the radios in a simple mode, with just the frequency number needing to match between the two radios.
Best regards.
Oct 17, 2010 | Motorola Walkie Talkie 2-Way Radio
Motorola T5420 won't transmit to each other.
Since you say the frequency is set the same, you possibly have the code set differently. Check your interference eliminator code. It must be set the same on all radios. For basic operation turn the code off (zero).
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5300_T5400_User_Manual_E.pdf
Best regards.
May 16, 2010 | Motorola Talkabout T5420 (14 Channels)...
Can transmit to a FV700 moto, but FV700 cannot hear me. Same Ch 6 and code 1
Not certain what model radio you are using to transmit, it is possible your radio has a Qt filter. If so, set it to zero. If this does not solve the problem, try setting your Code to zero also.
Best regards.
Feb 20, 2010 | Motorola T8500 Two Way Radio
I have two motorola Talkabout T5720. Identical models, identical s/n, but they don't work as a pair. When set to the same channel and same code...or even when theres no code encryption selected, they wont...
One further thing to check would be the Qt filter.
If the frequency, code and Qt filter are all set alike, and the radios still do not function together, you likely have a defective radio. The only way to determine if one is bad is to introduce a 3rd radio into the group, and the bad radio will be apparent right away.
Best regards.
Feb 19, 2010 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout FV700 not transmitting nor receiving
had the same problem...took out nimh...replaced with triple A...works great!!
Thank you!!
Dec 26, 2008 | Radio Communications
Motorola talkabout sx700
Check your "code" setting. You may be on the same channel, but different codes. The code is the smaller number. Check your owners manual if you have one for resetting the radio to the factory default settings. This will clear any programming issues.
Aug 15, 2008 | Motorola Talkabout SX700 2-Way Radio
Motorola Talkabout T5420 (14 Channels) 2-Way Radio Logo
405 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
