Question about Apple MacBook Pro PC Notebook
Macbook Pro goes from gray apple screen to black
I have a Macbook Pro running leopard. My mac goes from gray apple screen to a blank black screen and stays there. I'm not sure what is going on. I have recently removed my boot camp partition as well as downloaded updates since the last time I have restarted so I'm not sure if that is conflicting. I tried booting in safe mode and nothing helps.
Posted by green_j_l on
  • Anonymous May 18, 2009
    My MacBook Pro 15inch goes into a really messed up screen when I turn it on. The 1/3 of the top screen is black and the rest is gray with some colors blended in. When I connect an external screen I manage to get up the login window and log in, but when I use my Leopard Instal DVD the MacBook won´t output a signal to the external screen.
  • Anonymous May 11, 2010
    Try inserting the os 10 leopard disk and holding down the c key while restartng. Use the disk utility to check for problems. If none found restart while holding down the option key and see if you get the leopard disc and mac os as choices.... you may have left some pc os files even though you erased the partition... worth a try...
Anonymous
  • 30 Answers
The next step would be to boot in "Target mode" and for that you will need a fire wire 400 cable and another Mac. Connect the MB Pro to the other (working) Mac and restart the MBP while holding the letter "T" on the keyboard, that will allow you to see the HD of the non-responsive MBP (orange color drive shown in Finder) from there you can do a premissions repair and see the HD. Most likely from what you describe, the issue is the HD in your MBP. I have fixed a few of those problems by running TechTools Pro via Target Mode. Hope that helps!
Posted on Jul 08, 2009
Adam McNutt
  • 45 Answers
Try booting into single user mode by pressing Command+S while booting. You should then be at a prompt. Type in:
fsck -f
and press Return. Let it run and see if it corrects any filesystem issues, then reboot when it's done.
Posted on May 02, 2009
Gray screen on macbook pro
does it chime?
could be ok if it chimes.
could be bad ram, bad hdd, spill damage, liquid damage, might need new logic board. Places on ebay offer repairs for flat rate for about 250 bucks.
Feb 12, 2014 | Apple MacBook Pro Notebook
I am running OS X 10.4.11 and would like to upgrade my operating system?
Please provide more information.
To what would you like to upgrade it?
Since OSX Mavericks was just announced, I'm going to assume that's what you're wanting to upgrade to.
Not all Macs can run Mavericks.
Mavericks Capable Macs
Mavericks, like its predecessor Mountain Lion, requires one of the following Macs with at least 2 GB of RAM and 8 GB of available hard drive space:
  • iMac (Mid 2007 or newer)
  • MacBook (Late 2008 Aluminum, or Early 2009 or newer)
  • MacBook Air (Late 2008 or newer)
  • MacBook Pro (Mid/Late 2007 or newer)
  • Mac mini (Early 2009 or newer)
  • Mac Pro (Early 2008 or newer)
  • Xserve (Early 2009)
If your Mac isn't one of the ones listed above, you won't be able to upgrade.
If you have an iMac, MacBook, MacBook Pro, or Mac mini model that was originally released in Early/Mid 2006, the latest version of Mac OS X your system supports is Snow Leopard.
http://store.apple.com/us/product/MC573/mac-os-x-106-snow-leopard
Oct 23, 2013 | Computers & Internet
Lost install disk for Mac book pro My 13" Mac book
You will need some install disks to even begin working on your issue.
Your options:
  • Find someone with the same model MacBook Pro and borrow the disks.
  • Buy a copy of Leopard (10.5) or Snow Leopard (10.6) and use them. If you are going to buy a set you might as well update to Snow Leopard (10.6)
  • Check eBay for install disks but make sure they are for the same model MacBook Pro.
  • Contact an Apple service center and purchase a replacement set of install disks.
Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
Apr 23, 2011 | Apple Computers & Internet
My problem i install win xp on mabook pro model a1278 vga and sound and nework card not installed and i want driver for win xp
you need to insert the leopard or snow leopard dvd into your macbook while you are bootcamp to win xp.
run the bootcamp and it will install the drivers for sound, nic, wifi etc.
also download the latest bootcamp drivers from apple.com
Mar 28, 2011 | Apple Refurbished MacBook Pro 2.6GHz Intel...
Macbook pro screen boots to black. tried rebooting, screen comes on then goes black again. This happened after I unplugged it from a dell projector. Any suggestions???
Try pulling the battery out then holding the power button for 10 seconds. Put the battery back in.
If not search macbook pro recall apple has extended the warranty on some models due to a bad graphics card.
Feb 02, 2010 | Apple MacBook Pro Notebook
Can I upgrade my Macbook Pro to more than 4GB ram?
4GB is the MAX but only 3GB is utilized.
What Os are you running. Tiger Leopard Snow Leopard?
Nov 23, 2009 | Apple MacBook Pro Laptop Computer with...
Web camera use in apple pc in windows xp
When youre running windows XP on a Macbook, you should install the Bootcamptools from the original Mac OSX Leopard DVD. This installs all the components of your Macbook including graphics, Bluetooth and of course the iSight =)
Jan 20, 2009 | Apple MacBook Pro Laptop Computer with...
Audio driver for Macbook pro
The drivers for XP are on the official OS X Leopard DVD. Install this when running XP and then run the Apple Drivers Set up on the disk.
Apple MacBook Pro PC Notebook Logo
673 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
