Hi i have this usb tv box. the name on it is SKYDUDE.i have installed it and the images work perfectly but there is no sound. i have tried almost everythin but it doesnt seem to work. can u help?
You haven't mention about the connections you have with the SKYDUDE TV box. TV boxes usually have AV (audio and video) connections i.e., two seperate connections for audio and video signals. If you are using a set top box to connect to the tv box you can connect the "video out" of the set top box to the "video in" of the tv box using a cable. and "audio out" of the set top box to the "audio in" of the TV box using another cable. Some TV boxes don't have the "audio in" option. In that case you have to connect the "audio out" from the set top box directly to the "audio in" of the computer. This pin you can find just near the "speaker" and "mic" connections.
If you have an S-Video pin in your TV box, you can use an adopter wire to connect two "audio in" and one "video in" connections to the same pin. And you have to select S-Video option in the software installed.
If you have "RF in" option in your TV box, you can use use AV to RF converter to connect your set top box to the TV box.
Thank you,
Works great to split our Apple TV Amazon com MALLCROWN 4 Port 1080p HDMI Splitter with Ac Power adapter...
