I press the button for the oven and hear the clicking sound like its turning on and the light indicating the oven is on is lit, however the oven doesn't heat up.
oven is about 2 yrs old
frigidaire electric range
es300
please help
thanks
SOURCE: My Frigidaire es300 gas range
To Set or Change the Temperature for Baking
The oven can be programmed to bake at any temperature from 170°F to 550°F (77°C to 287°C).
To Set the Controls for Baking:
1. Press "Bake" key. "— — —" appears in the display.
2. Within 5 seconds, press the up or down arrow . The display will show "350°F (177°C)." By pressing and holding the up or down arrow, the temperature can then be adjusted in 5°F increments (1°C if the control is set to display Celsius).
3. As soon as the up or down arrow pad is released, the oven will begin heating to the selected temperature. When the
displayed temperature reaches the desired baking temperature, the preheat indicator light will turn OFF and the control
will beep 3 times.
4. To cancel baking, press "Clear/Off".
To Change the Oven Temperature after Baking has Started:
1. Press and make sure the bake temperature is displayed.
2. Press the or pad to increase or decrease the set temperature.
To Set Control for Continuous Bake or 12 Hour Energy Saving
The oven control has a built-in 12 Hour Energy Saving feature that will shut off the oven if the control is left on for more than
11 hours and 59 minutes. The oven can be programmed to override this feature for continuous baking.
To set control for continuous baking:
1. Press and hold "Timer On/Off" down for 5 seconds until tone is heard, " — — hr" will appear in display for continuous cooking.
The current time of day will return to the display.
2. To cancel the Continuous Bake function, press "Timer On/Off" and hold for 5 seconds until tone is heard. "12hr" will appear in
display indicating that the control has returned to the 12 Hour Energy Saving feature.
SOURCE: My Frigidaire 30" oven ES300 the broiler element
Hi
Error F10 appears due to a faulty oven temperature sensor or faulty wiring on the oven temperature sensor. F10 indicates that the control detects a runaway temperature in the oven. If this error is appearing when the oven is at high temperatures then it is due to a faulty relay on the electronic control board. If this fault code appears when the oven is at room temperature, then the failure points to a failed oven temperature sensor probe circuit or a bad electronic oven control board.
To check this you’ll need to use a multimeter, the resistance of temperature sensor should be around 1100-1200 ohms. If it is above 2000 ohms then the sensor has turned bad. However, if the reading is between the specified range then check the wiring harness connection directly at the electronic oven control board (with the range still unplugged). If the wiring is perfect then you would need to replace the electronic control board. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
SOURCE: Frigidaire FEF336ECE oven and broiler
Here is the part that you need... checked a couple of sites and they all say thet it is out of stock...
http://www.repairclinic.com/PartDetail/Oven-Control-Board/1194732
If you look around you may find it in stock somewhere...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
