Universal remote control setup codes to check with Akai Brand TVs are 0105 0002 0077 0254. If you wish to get more codes to different other models of remote controls, check this link.
U have the tv original remote wright?Yes?Push the tv remote button that said Menu.Go into the tv Menu at already or goto PICTURE than go down to do a resetting than everything will return itself back to the factory setting and now just go to the Colors Setting lower -30 less than the colors on the tv now ur tv should be good and have a correct pictures coloring.
look in your guide and check the programming procedure for finding an unknown code. it's usually turn the tv on and go into a search mode on the remote and start hiting a button till the tv goes off and then you have just found the code. good luck.
The speakers on these are usually at the bottom and do come off the set. If they are on the TV make sure there are wires connecting the speakers to the back of the TV at the speaker terminals.
The Power Supply Board is listed below. Please note, there are 2 models with the same beginning number (PDP4294). Verify your model number before selecting the Power Supply Board as each board is different depending on the model number.
