First; turn the water of to the machine next, remove the water line in front of the filter using a large bowl place the loose hose into the bowl and turn the water on for a minute turn the water off and, check the bowl for particles then reattach the filter and do the same thing on the other side of the refrigerator if this water is clean the interior refrigerator filter must be checked usually it is the carbon filter inside the refrigerator that is bad you can find the drawings location and, procedure for this part at: searsparts.com
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
