Hi. when i start to restore my audio driver the error dialog appear as (device object not found)con u help me to solve the problem. thankyou.
Most likely a faulty sound chip, disable it in cmos and use a plug in sound card.
[email protected]
First please refer to the following thread to see whether it helps.
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=796452&SiteID=17
I know that you are unable to start the current vista operation system and getting the error 0xc00000e9; the issue can be caused by the damaged system files or hardware device. You might first follow the steps below to exclude the possibility of system corruption.
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Click on the link mentioned below and it pop up for run now option. Run the automated fix it now.
http://support.microsoft.com/kb/948481
If this does not fix the issue, follow the manuall steps mention in the article or same is below:
Click Start
Also try these steps :
After installing drivers, Run Windows update and that install altest drivers.
Thank you
091-9916828137
Is the sound card enabled in the BIOS settings?
