Computers & Internet Logo
Anonymous Posted on Apr 25, 2009
Cannon printer offline
My cannon bjc2100 printer is offline and therefore wont print
Anonymous
Level 2:
  • Expert 54 Answers
  • Posted on Apr 25, 2009
Anonymous
Expert
Level 2:
Answers
54
Questions
Helped
28283
Points
153
Hi. You haven't said what operating system you're using or wether or not this is a recent thing. However if you are using Windows XP or Vista you can go to control panel, printers and scanners, under XP, or printers and other hardware under Vista, right click your printer and see if there is a check/tick against use printer offline. If there is uncheck it and see if that works.
I hope that helps but without anything to go on its only a guess. Good luck
2answers
Why dose my cannon mg2150 printer print online but will not not print offline ?
Select the proper printer as your default ,, you may be printing to file instead of the printer,,
My printer wont connect to the internet and it says i am offline but the blue light is on and i have a cannon mx432 printer
go to printer folder right click on that canon printer there is one tab use printer offline click on that tab it becomes use online printer
it solve ur problem
Prints a test page...but nothing else..says is offline
try on the print menu open file and you will see offline click on it to change to online and let me know again if we can try another solution
My cannon ip6000D printer is saying its offline and wont print.. please help
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
6helpful
Just set up cannon PIXMA MX870 printer. Cannot get it to print from wireless connection. In my printer box it says the printer is offline. It will print when I connect the printer with a cable. I use a...
I had the same problem - my printer showed that wireless LAN was enabled & my mac showed the printer but said it was offline. I went to preferences, print & fax, hit the + key to add a printer, added the canon printer again, set that printer as my default, did a print command from Word & that created a queue in the new default printer ... and it printed. Deleted the first Canon printer that was "offline." Oh, and I'm not sure if it made a difference, but before what I just described, I checked for software updates after the printer CD install process & uploaded one update.
Cannon printer mx860 says offline cannt print from computer how do I fix
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
Also on the computer:
Start-->printers and faxes-->right click on the printer-->properties-->make sure it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
My compter file says that my Cannon imageclass 2300 is offline what is the prolem?
Go to the CONTROL PANEL on the computer, select PRINTER?FAX icon, then click on the name of the printer you want to associate with your printing needs and make sure it is connected. This will allow the print jobs to go..... Please let me know if there is any thing else you might need, of if it is still offline, we can go further! Guy :) Pleasure to help out.....
I have a cannon inkjet mp560. when ever I try to print it says "printer is offline" or "printer is not responding. I've tried unplugging the usb cord and turned it off and restarted it, but it will not...
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Grand Canyon Tech
Grand Canyon Tech
