Hi my N95 display keeps on showing blank black
display every 7 or 6 secs. normal dislay for 7 secs then 1 sec blank
continuesly. At powersaver screen date and time it just blinks and
blinks.
I tried reseting * 3 call power but o joy, it'll just be normal
after a few minutes then problem starts again. or when I turn off then
on the phone.
Also format mem card and also hard reset.
I had this problem when I played n-gage for a few days then it had
this problem also, when someone borrowed my charger for one day I use
N73 charger.
Fuser Heat Error. Sometimes this code can be cleared by using the reset procedure outlined below. If the code returns then you will need to have the unit serviced.
Reset Procedure:
1. Turn main power switch OFF.
2. Turn main power switch ON while pressing the Menu/Select key.
3. Keep pressing the Menu/Select key until the LED turns OFF on the control Panel.
4. Check to make sure that "Trouble Reset" is displayed on the control Panel
after LED turns OFF.
5. Pressing the Menu/Select key.
6. Check to make sure that "OK" is displayed and the it has been reset.
7. Turn main power switch OFF and ON again, and make sure that the machine properly
starts.
I purchased Micromax Van Goh last month. Within few days of usage it is giving following error when I try to use camera or camcorder:Error ''Camera Module Not Ready''. Any solutions?
Hi Friend, Please find the below mentioned steps and kindly follow the steps,
1.Switch off the mobile. 2.Remove the sim card,battery and memory card. 3.Hold the switch on button for 20 to 30 secs, 4.After that replace the sim card and the battery. 5.Now switch on the mobile, 6.After it has switched on now replace the memory card.
Syncronisation sequence is in the user manual.
syncronisation is as follows.. 1) Press T to activate touch system. 2)touch the screen centre to show units display. 3)hold T button for approx 5 secs till the hands point to 12o clock. 4)use the + & - buttons to control the minute and hour hands... you must syncronise them both to 12 oclock exactly. 5)when you have them both pointing to 12 exactly, press the T button to finish the sync. the hands will now go back to the time.
If the hands often go out of sync, the battery is probably worn and will at some stage the 'bat' warning will appear. (this initially only flashes every 20 secs, so watch the display for over 20 secs to see the 'bat' warning. eventyually this becomes permanant display). Batteries normally last about 6 years
when i turned on my K750i display is recently white blank for few sec and then become black for few sec again and only so. Nothing else appear on display what i should do? Help me please!!
