Seagate Barracuda 7200.7 40 GB Hard Drive Logo
Posted on Sep 26, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The hard disk in drive D: is not accessible
Local Disk(D:) is not accessible Access is denied
  • arshal Oct 30, 2007
    Thre is no security tab becouse file system was fat32
Anonymous
Level 2:
Novelist:
Scholar:
  • Expert 104 Answers
  • Posted on Sep 27, 2007
Anonymous
Expert
Level 2:
Novelist:
Scholar:
Answers
104
Questions
0
Helped
50167
Points
194
Well this message can be two things(if not more) One of them being that the disk has security set and you wil need to change those settings if you want access to the drive the other scenario being that a program has locked the disk for exclusive access. Assuming you are using Windows XP. To check the security go to the properties of the disk then click on security(Tf the security tab isn't there, Open my computer then click Tools->Folder Options then the View Tab. Scroll to the bottom/last option then uncheck Use Simple File-Sharing press OK/Apply) Now back to Properties of the disk then Click the security tab. You'll need to try this first and tell me what's there, or if u got any error message etc. My explanation might be to long if i try to explain every possibility. regards, babb
anjuna
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 30, 2008
anjuna
Contributor
Level 1:
Answers
Questions
Helped
555
Points
0
A program has locked the disk for exclusive access.How can I over come the lock?
A
Anonymous
This sol'n not working give other sol,n
4 Related Answers
Anonymous
  • Posted on Jun 12, 2008
SOURCE: Local Disk(D:) is not accessible Access is denied
hi , got the problem with my maxtor hard drive
error message is
.D:\ is not accessible
Error performing inpage operation.
done the virus checks driver updates,system restore but nothing works, comp is very laggy when trying to use it, tried turning the power of to the D drive and that fixed the problem with the lag but no cant get into my back up drive which is the D drive.
plz help if u can
Anonymous
  • Posted on Nov 23, 2007
SOURCE: The disk in drive D: is not accessible
i had a similar problem.... but since it was on an extra portable hard drive so i backed up the entire data on it and went in for a full format that got me rid of this problem.... this peoblem came to me after norton discovered a virus on my drive and in order to remove that it deleted a couple of files maybe in that process i lost a couple of files required for dbl click access to the drive(though i was able to access the drive through explore in the rt click menu)......anyway format solved it so go in for that....
or run a virus scan
or i found another way on microsoft site try it maybe it ll help...not too complicated.... http://support.microsoft.com/kb/307874/
good luck.....
Anonymous
  • 2351 Answers
  • Posted on Feb 18, 2008
SOURCE: The hard disk in drive D: is not accessible
Goto this link & download the utility to fix/test the drive.
http://www.samsung.com/us/support/download/supportDown.do?group=&group_cd=&type=&type_cd=&subtype=&subtype_cd=&model_nm=SP0822N&dType=D&vType=L&mType=SW&model_cd=&menu=&prd_ia_cd=&acc_ia_fl=&disp_nm=SP0822N&isEqualsY=&cate_type=all&language=ENGLISH
Anonymous
  • 158 Answers
  • Posted on Jul 09, 2008
SOURCE: "Access is Denied"
you need a file called takeownership which when run installed to the reg it gives you the option of taking ownership removing that anoying Access Denied screen.
google for it I did and it works a treat.
good luck
1helpful
2answers
I cant access the d partition on my hard drive
Hi...
Do you want to access the drive d and get your files. You can not access it when you double click the drive. The drive will says access denied. To access the drive d open My Computer you can see there a address, there is and arrow there just click. Chose the drive d to open i am sure that you can open it.
Regards
PCmania
In my system have c,d, e, and f drives.i can access c,d,e and but i can't access the f drive..while accessing my f drive ''f: drive is not accessible''.access denied.but it appeare in local disk manag on...
just format the drive and check . After that if the drive not opened then go to disk manager and delete that drive and again creat the drive then check
Hope I can help you with your problem. If your hard drive was installed to be used as D: in your old computer then you will have to set it up to be D: in the new computer. This may be why it is not being recognized. You can do this by connecting it as a slave on the primary IDE cable.
Also you will need to check the jumper on the hard drive to make sure it is set in the slave position.
1helpful
"Access is Denied"
good luck
1helpful
2answers
My Toshiba lap top when i try and copy pictures to a disc it will not let me it says D:/is not accessable.incorrect function
I also tried downloading pictures from a cd and it would not read it though it did read a pdf file for documents on another disc
1helpful
2answers
first u have format the c:drive the problem is solved
if not u should format all over the system
2helpful
3answers
I recently had this problem. Whenever I clicked on any of the drives a window appeared with warning which said drive not accessible. Access is denied. Previously I thought that it is a virus which has edited my registry and is not allowing me to enter or even view my content. So I formatted the whole system but that didn't help. Now I am sharing this with you.
  1. Open My Computer. Goto Tools>Options. Goto View Tab Pane. Uncheck the last Option in the Advanced Setting which says Use simple file sharing(Recommended). Apply the setting.
  2. Open the properties window of the drive you are unable to access.Goto Security tab pane.
  3. Goto Advanced.
  4. Now click on the Owner tab pane.
  5. It's very rare that the ownership of the drive changes. But it happens once in a while.
  6. So if you are the user say Admin then select Admin(ComputerName\Administrator).
  7. Click on the box which says Replace owner on subcontainers and objects and click over Ok.
  8. Apply the changes.
  9. Now you should be able to access the drive.
Top Seagate Computers & Internet Experts
Marvin
Marvin
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
