Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi tv ws-55311
My tv WS-55311 has a problem it dosen't turn on, every time i try to turn on, the green light blinks twice and turn off, sameone in this forum suggest me to replace the power board for a new one, but it's to expensive. Any help woyld greatly appreciate Thanks
Posted by alfredoriver on
  • alfredoriver Apr 25, 2009
    I will do that thanks so much.
Randy McComas
  • 61 Answers
Mine did the same thing. It was too much money to invest in old technology. I chucked that baby to the curb and got a 42" LCD. LOVE IT!!
Posted on Apr 25, 2009
The green power light would come on, with no picture, for 3-5 seconds and then the power and the green light would turn off. I have reset the TV by unplugging for a little while but that has not helped.
When power light goes out on front of set press both the menu and input (device) buttons at the same time for at least 5 seconds and release both buttons.
The power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Sep 30, 2010 | Mitsubishi WS-55311 55" Rear Projection...
Green lite turns on for 2 second and then turns
Please listen and try this:
When the power light comes on and goes off, on the front of the set press BOTH the Menu and Input (Device) buttons at the SAME time and HOLD them both for at least five seconds and then release both.
The power light will blink a two digit error code and will repeat it about 5 times. To get it to repeat you would have to unplug the set and turn it on again etc.
The most common error is 2 blinks, pause, 2 blinks.
Let me know what error code you find and I will direct you as to what it means and what may have to be done.
SD TECH
May 13, 2010 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubshi ws-55311 turns on and then turns itself off
no, if blink code the problem is in the TV set--cable will not cause this type of trouble
Aug 27, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Cannot turn tv on
mine required a bulb replacement it wasn't that old at the time
don't like being turned on and off a lot
Dec 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Bad convergence, now wont turn on at all.
The convergence ICs have failed and thats what is shutting the set down. You will need to replace both convergence ICs they are STK394-250 you can get replacement ICs at the following link with free shipping and free instalation instructions with pictures s you can do the repair yourself. Here is the link.
http://servicemanuals.vstore.ca/
Jun 30, 2008 | Mitsubishi WS-55311 55" Rear Projection...
TV WON'T TURN ON
You might have a bad power supply or convergence circuit, I also suggest you to check for fluid spill on the circuit board. if the convergence is defective one of the 5A picofues on the power supply is open. Hope this help you.
Jun 20, 2008 | Mitsubishi WS-55311 55" Rear Projection...
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
191 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
