Got a flat tire on a mountain bike doesn't seem to have a tube
Inner tubes commonly lose air when stored for as little as a couple of months and quicker when cold. They also tend to dry out and leak as fast as you can pump. Replacement tubes are available at bike shops and even less than $6.00 bucks at Wal-Mart.
To replace(The long version,cause the short version not good):
Remove wheel from bike, trike, trailer, etc. and deflate tube completely. You will need 2 box end wrenches (the ones with the closed ends, because these are not sharp). Insert box end of wrenches next to each other between rim and and one wall of tire, now pry the wrenches back so as to pry one wall of tire to the outside of rim, now alternatingwrenches, slide wrenches away from each other to slowly walk one wall of tire outside of the rim, reach in and grasp old tube and pull it out. Now straight new tube out remove plastic fill cap(put cap in your pocket), reach in and insert filler into hole in rim, now working your way around with your fingers to push tube up into tire(carefull not to let it get twisted), now put cap back on tube so you don't loose the filler, now work your way around with your fingers to push tire back into rim, you may need to use the box end of the wrenchto help pry the last bit of tire back in(Just don't pinch the tube between wrench and rim while doing this, lest you now have a new hole to fix), now grasp filler so you don't loose it, add air to amount shown on tire, and RIDE ON!
