Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a Dell Dimension 5150 trying to replace cd drive!
I got a new dvd drive for my computer, but I can't seem to get the old one out. So I was wondering if someone could help me get the old one out.
Thanks!!
Posted by mtooley on
Anonymous
  • 433 Answers
As you are look at the front of your PC remove the right hand side. The you will see a spring loaded latch that when pushed up will release the CD/DVD players from your computer. Make sure you remove the cables in the rear of the drive. The panel around the drive area is removable without taking off the whole front.
The drive itself removes straight out of the front... Install lift up that same spring loaded latch that covers all three drive slots.
Hope this helps...you can do it ...have fun
Posted on Apr 25, 2009
Installed a new WD Caviar into a Dell Dimension 5150 to replace failed Hard Drive. Wont boot on start-up. A cant find drive message comes up. F1 through it and starts up OK. Seems to be recognising the...
Restart your computer.
Enter BIOS SETUP.
Check the list of disk-drives (and CD/DVD drives).
You have "manually" added a device that no longer is connected.
So, you get the "cannot find drive" is generated.
Disable/Remove the non-existent device,
and then you will not need to press 'F1' to continue.
Nov 07, 2010 | Computers & Internet
My dimension 5150 does not burn cd's any more
CD/DVD drives are even less reliable than the cheap power supplies generally used in packaged PCs. Of two new, brand-name drives by Lite-On, one was DOA and the second ran for 2 days.
You can try removing (deleting) the drive from the Device Manager list, then rebooting. If the drive is at all usable, Windows should 'find' it and reinstall the driver needed.
If this doesn't work, the drive is likely dead.
Aug 14, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 CD door closes quickly.
If an application is attempting to access the CD drive, the door will close. Put the CD in first and then launch the application.
Also possible a problem with the eject/load mechnism in the CD drive.
Oct 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
CD-rom can not read or burn, but DVD-reader in
Try to ship it back where you purchase that device cause the hardware device has the problem maybe a factory defect then you should ship it back. Try to used light scribe utility program on your writer cause it will help your dvd/cd device read properly.
Jun 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Issue Installing 4th Drive Device (2 DVD Drives and 2 Harddrives)
You cannot plug an IDE ribbon in the floppy slot (port). The total IDE drives you can install is four (4). But check your jumper configuration. The DVD & DVD/CD-ROM cannot have the same jumper configuration to share the same IDE slot. One has to be MASTER (MS) and the other SLAVE (SL). Or you may put both drives on CABLE SELECT (CS).
Apr 21, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Philps DVD/RW DVD8801 will not let me burn cds
First thing to do is go to the manufacturers website or dell.com/support if it is an OEM drive
download the driver for it. Make sure you save it and not run it now what you want to do is follow these steps in uninstalling the old driver and installing the new one
Go to Start Button
Click control panel
System and maintenance
System
then in the left pane you should see an option for device manager go inside there expand the category for cd/dvd/rw drives
right-click on the drive and click uninstall
then you will want to install the freshly downloaded driver and then reboot
a few things you can get back to me on :
-what program do you use to try to burn?
-what OS are you running?
If these steps seem difficult let me know and i will give you a screenshot walk through. I need to know the OS for that . let me know if this helps
Mar 22, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 cd-rom stopped working
Open your tower and reseat all the cables that are running to the CD ROM (generally a flat white cable). Also reseat the other end of the cable to the motherboard too.
Ensure that CD Drive is enabled in BIOS (Press F2 as the system boots up to enter into BIOS) Please get back if you need any further help.
Jan 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 DVD Players Will not play
maybe the carbons of the DVD reader are getting too old and it doesn't rotate as fast as how it was burned so it cannot read the movies..
buying a new one will fix your problem..
the problems of nano technology is that things are too small to be fixed by humans...
maybe you could play those games because they were old, and since most of the stuff its installed in your computer it doesn't need much from the DVD unit..
Dec 07, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
87 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
