Question about Electronics - Others
Audio problems I have a generic mic on my pc. It was working with my old webcam, but now with my new one, it is not. Suggestions?
Posted by cubbair on
Anonymous
    Scholar:
  • 150 Answers
Your mic settings might have changed on the program you are using with your mic. Check the mic settings and make sure it is set to the right hardware.
Please rate, thanks!
Posted on Apr 24, 2009
Pc webcam ywb-1016, video works, but audio(built-in mic) doesnt
You may have to tell your computer what mic you wish to use ( make it default )
Typical audio set up
Laptop/mic x webcam/mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
Jan 19, 2010 | GE EasyCam Webcam
Webcam recorded audio have interferance
make sure you only use 1 mic .if that dont work try pluging in a diff mic. most laptops have built in mic's it might be bad disable it in control panel and use new mic
Oct 07, 2009 | Toshiba Satellite A135-S2386 Notebook
No sound on webcam video call ONLY
You will probably need to reconfigure whatever software you are using for the video call to pull audio from the Onboard Mic from the Cam. If it is not configured to pull the audio from that Mic on the Cam, it may be looking for audio somewhere else. This is sadly an issue with a lot of Video Chat software applications.
Jun 19, 2009 | Microsoft LifeCam VX-6000 Webcam
Problem with my A4Tech view cam with built in mic
Make sure that you select the correct source for the voice or recording in the Windows sound settings (control panel).
If multiple audio solutions are installed, the default is mostly the sound card input. You need to select the microphone from the webcam.
More generic Webcam troubleshooting:
http://www.pcauthorities.com/pc-errors/how-to-fix-webcam-problems
Jules
Oct 16, 2008 | Computers & Internet
The microphone does not work
Hi
Try booting in safe mode and reinstall the mic,sound(audio and video)driver and the web cam driver as well...
Good Luck
Genius Guy...
Oct 15, 2008 | Microsoft LifeCam VX-3000 Web Camera
Web Cam Mic
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Desk Mike or Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Jul 26, 2008 | Labtec Webcam Pro
Mic doesn't work on Creative Notebook Cam
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Jul 04, 2008 | Creative Labs Creative Webcam
Minicam mic
i have the same problem. were you able to figure it out?? help! thanks.
Jan 12, 2008 | GE MiniCam Pro HO98656 Webcam
Lifecam video works great - but no audio!
do a cam/mic test in the audio/video settings in the tools tab in yahoo/msn. Then you need to minimise the yahoo/msn screen and right click on the cam icon in the taskbar and check that the mic and cam are enabled and that it is set to allow other programes to take control of this device
Dec 02, 2007 | Microsoft LifeCam VX-3000 Web Camera
Mic
first u check whether your mic is correct, try to plugin some other pc where mic is working in good condition,
if the new mic is working properly on another pc then
Re install your sound card Driver, and try
Cheers
Nov 30, 2007 | Philips SPC 200NC Webcam
Electronics - Others Logo
26 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you an Electronics - Other Expert? Answer questions, earn points and help others
