2004 Dodge Durango Logo
T
Todd Krueger Posted on Oct 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I replaced a factory stereo in my 2004 dodge durango with a used factory replacement. It worked fine. But now the durango won't start. The dash lights flash a few times and there is a clicking noise, but then nothing.
Trevor Marsh
Level 2:
Habit-Forming:
  • Expert 114 Answers
  • Posted on Oct 17, 2013
Trevor Marsh
Expert
Level 2:
Habit-Forming:
Answers
114
Questions
Helped
42874
Points
368
Sounds like a security system or alarm problem?
5 Related Answers
Anonymous
  • 85 Answers
  • Posted on Jul 03, 2008
SOURCE: 1999 dodge durango fan motor replacement
  1. Remove right side scuff plate.
  2. Pull back carpet.
  3. Disconnect blower motor wiring connector.
  4. Remove blower motor retaining screws, and lower blower motor assembly from unit housing.
Frank Magliocca
  • 1461 Answers
  • Posted on Dec 27, 2008
SOURCE: # 4 fuse blew out,
I KNOW YOU HAVE AN ELECTRICAL SHORT.WAS AN ALARM INSTALLED OR ANY OTHER TYPE OF ACCESSORY? CHECK WITH DODGE TO FIND OUT ABOUT A RECALL.IF SOMETHING WAS INSTALLED, TAKE IT BACK THERE TO STRAIGHTEN IT OUT IF NOT HAVE A AUTO TECHNICIAN CHECK IT FOR YOU.
Anonymous
  • 15 Answers
  • Posted on Dec 29, 2008
SOURCE: 2003 Dodge Dakota front end makes click noise only when in a turn
check that the caliper slides are free and that you refiited the anti squel plates on the back of the new pads
Anonymous
  • 574 Answers
  • Posted on Aug 23, 2009
SOURCE: security light blinks on dash , truck wont even try to start
Does your key have a chip on it? If it does its probably the problem
Anonymous
  • 111 Answers
  • Posted on Nov 27, 2009
SOURCE: 2004 Dodge Caravan won't start...just a clicking noise...
Check the battery first. Just because the lights are on doesn't mean it has enough power to start the van. If you or the van has a volt meter, the battery should read at least 13-14 volts to be good. If the battery is good then the alternator is good and we move on to the starter solenoid. I'm sure it's one of these. Do the lights go off or very dim when you turn the key? If so then battery.
Testimonial: "Thank so very much! It was the battery and easily fixed with a new duralast from AutoZone!"
Radio reset 2003 durango
Dodge Durango Stereo Removal 2004-2007 - YouTube
? 3:05
www.youtube.com/watch?v=LEuFEXBZobM
Mar 23, 2013 - Uploaded by Factory Car Stereo Repair Dodge Durango Stereo Removal 2004-2007 .... an amp inside tht if stock radio is removed it will not work unless u connect an adapter tht costs ...
Search Results
    images for 2003 dodge durango wiring
6helpful
2answers
My 2001 Dodge Durango won't start at times. I replaced battery and had alternator checked. Both checked out fine?? Help! ??
When it won't start, will the engine turn over and try to start, or does it act like a dead battery?
2004 dodge Durango, air will not blow, have checked all the appropriate fuses, replaced resistor, disconnected blower motor and checked it, it works fine....completely out of ideas. When the car is moving...
sounds like you have done all the hard stuff maby its the switch inside [on/off] on the dash that is not working properly.. i hope this helps its the first thing i thought of...
I have a 2004 dodge durango 4.7 engine oil light on dash stays on.
I would start with a new oil pressure sender its a cheap fix, easy to replace, and a very common problem for this vehicle
How do i remove the factory stereo out of my 2002 dodge durango and replace it with an aftermarket stereo and also getting the speaker to work if they are amped
take the plastic thing off that goes all the way around the guages or w.e. then ther should b 2 bolts on the front of the stereo take them out. take out the radio n unconnect wires. then get a wire kit n plug it in and hook it up. if the speakers dont work either get new ones or rewire them using all different wires.
2answers
Replacing radio, need to know how to remove dash
dash is ismply snapped into place. There are only plugs in teh dash if your model is a 4wd. It's easiest to tilt the steering wheel all the eay down for removal of the dash bezel. Once the bezel is removed there are only two screws holding in the factory radio.
Stereo not putting out sound
amp may be inside stereo or on rear speakers.
Factory alarm won`t let start my durango 2004
lock your doors from inside shut door and unlock from out side then try to start.
3helpful
HOW TO INSTALL AMP INTO A FACTORY RADIO IN DODGE DURANGO 2002
You can buy adaptor plugs that allow a simple hook up at most car stereo places.  However, when you increase the power going to the speakers you also have to replace the speakers to handle the higher power or you'll toast them.
No power to stereo or power locks
Checked all fuse in dash are, as well as power distribution box under hood?
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
