1. Sometimes it works fine. Getting more rare.
2. Sometimes the water drains out as it is coming in (filling) and will continue to do this for hours if not caught.
3.Sometimes the cycle will start when knob is pulled out and sometimes it won't. It will also stop in the middle of a cycle (between filling and agitating for example) and stay there indefinitely.
4.If I bang the lid down and/or rotate the knob to other parts of the cycle or other cycles, it sometimes starts. Sometimes I have to do this repeatedly. (Admittedly this probably isn't the best thing to do :) but hey, we need clean clothes occasionally!
Thank you, we just tried repositioning the hose, it seemed like some pressure was released and the machine is filling without draining right now. Thank you so much! The connections on the timer seem to be tight, so we'll order a new one as well as a lid switch. Now we just need to figure out how to remove the timer.I really appreciate your help, this has been a major annoyance!
Thank you!
I have same problem. - 2 loads ok bu tth e3rd one do not work- Why itis ok in 2 loads but not the 3rd loads? Or ramdomly stop the washing,
#2. The drain hose is too low or no air gap where it enters the wall drain.
#3. Could be a bad timer or just loose connections. Open the control panel and unplug then replug the timer wire harness.
#4.Bad lid switch. It must be replaced.
