There is a cold start "sequence" which is suppose to reset the engine controls as if you had a choke. This sequence is triggered by water temperature sensors on the engine.
This sensor is different from the one operating the dash gauge. It is probably stuck on a "hot" setting and the engine controls do not reset.
A tune up>
its flooding,
egr valve stuck open?
does hot engine starts and restarts , always work?
SOURCE: 91 F-150 300 six starts fine, then runs rough,
check idle air controll motor, Lightly tap it while vehical is running, If this helps, you will need to replace it, usaly 55.00 at the zone
it needs to be put on a computer to have the airbag computer reset
