Question about Cisco 7912G IP Phone
CONFIGURE ip pHONE 7912G
HI PLEASE TO CONFIGURE CISCO ip phone 7912G with ccme
Posted by rasmane_niki on
  • Anonymous May 11, 2010
    CCME can be a little difficult for the standard end user. I would recommend you contacting your installer first, and see what they tell you. Also, please clarify what you are needing to configure, as the entire configuration is a process.
Anonymous
    New Friend:
My phone cuts in and out. I am hooked up to a Rogers Rocket Hub with a static ip address.
Posted on Jul 12, 2010
Anonymous
  • 48 Answers
Here is the manual on how to Configure CCME, and this will apply to your 7912G. :)
Posted on May 21, 2009
Cisco ip phone 7912 is not working. when conecting in LAN then it will not boot, while another same series ip phone on that LAn port works perfectly. Only red and green LED blink continue in...
If it is getting an IP address, goto that IP address and there you will be able to see some console messages. See if alternate TFTP is set and is going to a different CM server. If so change it to the ip of your CM.
Aug 17, 2017 | Cisco 7912G IP Phone
Good day! How Cisco 7911G IP Phone can connect to the Call manager Cisco 7912G IP Phone?
You must have a valid functional callmanager. You then set option 150 in your DHCP which specifies the IP address of the TFTP server which is ultimately callmanager.
Nov 04, 2010 | Cisco 7912G IP Phone
Want to migrate fom sccp to sip protocol for cisco IP Phone 7912
Here's a great little document from Cisco directly, called "Converting a Cisco 7940/7960 CallManager Phone to a SIP Phone and the Reverse Process"
Easy to do, just follow the step-by-step directions.
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
Jan 21, 2010 | Cisco 7912G IP Phone
Cannot forward call
You need to create a call group for transfering. Secondly, you need to configure the caller id within the fxo module.
Dec 25, 2008 | Cisco 7940 IP Phone
"Edit" softkey is not working, Can't enter NTP or TFTP on Cisco 7912 phone
I would try logging into your CCME and deleting that phone from the user list. That way, it will have to contact your server and redownload all the necessary files. If that doesn't work, I would try using the factory reset code which would completely reset it. Both of these require that your server is up and running properly.
Sep 09, 2008 | Cisco 7912G IP Phone
You can not shut off CCM CSRST fall Back service. You need to either remove SRST reference in the device pool or for the phone specific configuration. I suggest you create device pool similar to one you have but without SRSR reference. Then you need to re-apply device pool in the phoone configuration and restart the phone.
Apr 22, 2008 | Cisco 7912G IP Phone
Cisco 7912 sip phone
Can you please make sure that you can ping the device - you might have a routing problem
Feb 28, 2008 | Cisco 7912G IP Phone
Cisco 7912g sip firmware
firmware can not be e-mailed to you unfortunately. The only way to oficially obtain the software - purchase it
Jan 02, 2008 | Cisco 7912G IP Phone
My Phone is on Busy Mode
Are you in a Call Manager envirnoment ?
Jun 11, 2007 | Cisco 7912G IP Phone
Cisco 7912G IP Phone Logo
484 people viewed this question
Top Cisco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Resolution IT Dubai
Resolution IT Dubai
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
