How to remove interior door panel on a 1997 dodge caravan with power windows
Start by removing the negative battery cable from the battery. Then locate and remove the screws that hold the interior door handles in place (they may be hidden by snap in, or snap on covers). Once you have removed the interior door handles, disconnect the wire clips that go to your window and door lock controls.
I personally use a small pry bar to remove the interior door panel; it is held in by plastic snap clips. Try to get as close to, or directly under the snap clips as possible with your pry bar to prevent them from tearing out of the door panel. Once you have released the snap clips, pull the panel upward to remove it. Install in reverse.
I hope this information helps you, and I wish you luck on your repair.
Undo the screws and plastic clips, lift up and pull out. Make sure you undo the bolt in the interior door handle, and the screw that holds the elecrical controls in. This will allow you to take the panel off far enough to unhook the connections to the controls and remove the panel completely. If it doesn't budge you forgot a screw or bolt somewhere.
REMOVAL
1. Remove the watershield. (Refer to 23 - BODY/DOOR - FRONT/WATERSHIELD - REMOVAL)
2. Remove door glass retaining clips and secure the window in the up position using masking tape or equivalent(FRONT DOOR GLASS CLIPS).
3. Disconnect wire connector from power window motor, if equipped.
4. Loosen screws attaching front and rear window guide rails to inner door panel (FRONT DOOR MANUAL WINDOW REGULATOR - TYPICAL).
5. Remove screw heads on guide rails from key hole slots in inner door panel.
6. Loosen screws attaching regulator to inner door panel.
7. Remove regulator from inner door panel.
8. Extract rear guide rail through inner door panel rear access hole (FRONT DOOR POWER WINDOW - TYPICAL).
9. Extract front guide rail through front access hole.
INSTALLATION
1. Insert front guide rail through front access hole.
2. Insert rear guide rail through rear access hole.
3. Place window regulator in position on inner door panel.
4. Place screw heads on guide rails in position through key hole slots in inner door panel.
5. Tighten screws to attach front and rear guide rails to inner door panel.
6. Connect wire connector into power window motor, if equipped.
7. Install door glass.
8. Verify door glass alignment and operation.
9. Install sound shield and door trim panel
DIAGRAMS CAN BE FOUND ON JUSTANSWER,COM
