you need to wire each sub down to 2ohms then wire them together like the one in this pic http://m.seimg.net/product/img/subwoofer_wiring/2_subs_DVC_4_ohm_mono_variation2.jpg witch will give you 1ohm so you will be getting every bit of power that amp has but you should get a bigger amp for thos speakers
wire the subs if thair dual 4 ohm . in parallel. red to red and black to black. giving it a 2ohm load. do the other sub the same. and conect it on the amp . turn your gain about 12oclock and db level less than 12oclock and your frequnecy around 80-100. and that should work
sounds like the amp is going into protection mode. maybe a sub is shorted (blown). Or, the only other possibility is the mosfet transistors on the inside of the amp are blown.
wire the subs at 2 ohm each. red to red and black to black and then to the amp. if thay are a dual 4 ohm sub. dual 2 ohms will need to be wired red to black on one coil and the other conected to the amp.
take the positive on the sub and run a wire to the other positive the run a negative to the other negative then to your pos and neg on the box do the same on the other side then tie your two positives and two neg together and you got 1ohm and that amp willl handle it all day
is the sub dual or single?check sub first then try disconnecting all power including ground for 20min to discarge caps some amps mute if driven hard at low impedience .
it wouldnt short it out or anything?
