Question about OKI MICROLINE 520 Matrix Printer
Cannot print Sometimes when i am running out of time and nervous, cannot print with my printer. Other time, when i am balanced and calm, i print with my printer successfully. Why is that? When i cannot print then alarm signal is red. Why i cannot print with a workable printer?
Posted by viragnoveny on
Anonymous
  • 4 Answers
Its most likely your printer communication with your computer is "laggy" if your using wifi printing you should reset your wifi modem. If you print with a cable try to blow both ends and jacks on pc and printer. If this doesnt help check if your computer meets requirements for best printing for this printer also try buying new link cable. But for this type of problem it would help more to contact your printers customer/ tech support because of its brand
Posted on Apr 23, 2009
  • Anonymous Apr 23, 2009
Malfunctioning
what type of sound, any burning sound?
Jun 27, 2013 | Samsung ML 2525 BW laser Printer
Hp Photosmart 6510 Black ink will not print
It is a known defect among many PhotoSmart printers, including the 6510. The black ink was programmed to fail at between 50 to 60 black print cartridges. One HP whistleblower said a bug in this programmed failure causes the black ink to suddenly stop printing after 5 to 6 black ink changes instead. When you call in, they offer to sell you a new printer! The service guy I spoke with was extremely nervous. I refused to buy a new printer, given I had put less than a ream of paper through mine. I was on hold for about 10 minutes, then told there was no supervisor, but given an email address to write to. Three weeks later, still no response. Yes, a class action lawsuit needs to happen, not just for the printer malfunction, but for the hours I soent trying to fix it, and new cartridges I bought, thinking I had bad ones.
Jan 27, 2013 | Office Equipment & Supplies
How to clean the print head as there are fine lines appearing on the photocopy
1. Many problems occur with print heads when people try to refill their own cartridges. The heads clog with time, especially if the printer sat for a long time unused.
2. You can try gently cleaning the heads with a lint-free cloth. You can also use the "clean print head" function that comes with many printers. This will use a lot of ink, but it usually cleans the print heads.
3. Some printers use cartridges that do not include print heads. If your printer is of that type, then your documentation that came with the printer should help you with specific instructions for your printer.
4. If nothing works, it may be time to retire your printer and get a newer one. The newer ones are far more efficient and usually use less ink than the older ones.
5. Remain patient and calm through this process. Do not throw your printer or other objects across the room or out the window. Further damages could result from that type of behavior.
Jul 16, 2011 | Office Equipment & Supplies
We installed the hp 3320 software on our new laptop. when we print items it sends it to the printer; however its printing blank. the cartridge is full. how can we fix this problem?
The problem is a "clogged" ink-path -- the ink is not getting sucked ("stucked" without the 'T') into the ink-jet mechanism, and is not getting sprayed onto the paper.
Use the HP Printing Assistant software to run a "head-cleaning" cycle, to see if the clogging can be done.
P.S. FIXYA _censors_ some words, e.g., 'calm' is OK, but switching the middle letters to be: ****
will be censored. :-)
Dec 08, 2010 | HP DeskJet 3320 InkJet Printer
I just replaced the black and cyan ink in my i960 printer -- now nothing prints at all -- blank pages. I checked to make sure all of the packaging was off the cartridges
Run the Canon printer-software to launch a "print-head-cleaning" task,
because you may have "clogged" ink-jets, so that no ink can be sprayed onto the paper.
Test to see if FIXYA "censors" some words:
Start with the word CALM ( calm ) and swap the middle letters: **** ( **** ),
as in the ****-shell model of Apple portable computer,
or a cell-phone that opens like a ****-shell.
Do you see <star><star><star><star> instead of the word?
How about STUCK ( stuck ) and omit the 'T' to become: **** ( **** ),
as in "the printer sucks ink from the ink-tanks and jets the ink onto the paper".
Dec 06, 2010 | Canon I960 InkJet Photo Printer
Clucking in the front end already replaced bushings and swar arm
Depending on the mileage - probably lower ball joints need replaced
mine came with no grease zerks - installed after ball joints replaced.
had clunking sound also - went away after new replacements.
Oct 04, 2010 | 2001 Dodge Caravan
There is static coming out of my speakers on my stereo. I I checke to make sureall the wires are connected properly and the power is plugged in securely. There is static with the sound on all...
Don't worry, it's more possible that you have the static electricity and through your stereo this electricity goes to the ground. Try touching another metalic surfasce (refrigirator, oven etc), try to change your shoes (especialy if your stereo is on a carpet floor and you walk on it) Sometimes when we are very nervous the static electricity on our body is higher. So keep calm.
Stelios.
Feb 20, 2010 | RCA WSP155 Main / Stereo Speaker
Messy print when using glossy paper.
ok. sometimes the ink for hp if its not photo ink will do that. go to your printing settings/preferences and adjust your ink out put to less and dry time to more. you may have to adjust a few times to get the right balance. if you dont want to set it up for all printing you can also change settings when your ready to print. . just follow same steps when you are going to print. but you have to do it everytime you want to print a photo. also make sure to set your paper selection to glossy photo paper
Apr 24, 2009 | HP Color LaserJet 2600n Printer
OKI MICROLINE 520 Matrix Printer Logo
152 people viewed this question
Top OKI Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
