Try to load from cd that was load into computer and followed on screen instructions now connect the usb cable from GPS to computer and went to some steps and at one point on screen will saynot communicating with gps memory card. A message says if you continue to get this error, please check the following URL for additional information www.garmin.com/usbgpsfaq. PLease help me out so i can use my Garmin Streetpilot i3 gps. Thankyou, Kenneth/lome
Haveing a hard time trying to download any updates. I dont have the disk eather for my unit. I have the streetpiolt 2720
Pls help me
Http://www.gpsinformation.org/i3/i3.doc
This link will tell you how to fix the problem. It involves making some changes in the registry so probably not a job for those not experienced computer users.
Same as lome on sep 24 2007
SOURCE: Garmin Streetpilot i3 GPS cannot load map to memory card
A way around this is to insert the SD Card into the computer (SD Card reader), point the directory to the card and install the maps like that. I had to do that the first time I bought my unit because I couldn't figure it out and got frustrated. So I thought of this easy work-around.
The Garmin C340 comes preloaded with maps while the I3 require that the maps be installed onto a micro sd card.
You can place the micro SD card into a SD adapter and use a regular card reader to download your maps. When the software ask for 'Device' to download to use the drop down arrow and find your drive letter associated with the card reader. Using a card reader will be much faster since the it is ubs 2.0 vs ubs 1.1
You could also go to Garmin website and download and install the USB drivers, see link below.
http://www8.garmin.com/support/agree.jsp?id=591
Can't load map update.
when I plug USB cord to puter and GPS 340 unit... it "chargers" the battery signal...
Cant do anything else from there
Placed ths disk in my computer and followed the directions
1. turn on gps unit
2. plugin usb
after this was done I kept getting an error message
Same problem
loaded cd and followed instructions gone into Ddrive but unable to get to setup mode
Yes, I have the same problem. I did as was instructed, but I keep getting an error message and a prompt to log onto this web site.
I tried loading several times, but to no avail.
Marvin [email protected]
went according to instruction. Turn on GPS, plug usb into gps and into usb port. Nothing happens.
garmin street pilot c330. Turned on gps according to instruction. Plugged in to gps port and then to pc port but nothing happened.
I tried to hook up my Garmin 330. The insructions tell me to turn on the GPS unit. I did. The computer doesn't recognize that it is on. I can't go any further.
same Maybe as unable to seek mapping function as also says cannot locate satellites. Maybe Vista is a prob lem? Is ther supposeed to be an antennae with this
Can not complete setup, sent to this site for help
The error comes up when I connect the garmin to the computer. It will not complete the download so I can continue the process. I have a garmin C330 model and I have tried this process on two different computers and I get the same error message each time. Please help so I can keep my garmin maps up to date.
non carica le mape
went through the on-screen setup and got to the last part where it says to connect the gps and turn it on and click next, but i keep getting an error message saying its not connected and gave me this url for the problem
yes
drivers will not load from cd
cannot load, if you continue to get this error signal, contact garmin.com
Have Model c330. Unit is on with "select a language screen". USB cable is properly connected, but program does'n recognize the connection and I get an error message.
Ihave model 330 Iloaded the CD and it had aprobel==lem saying if i continue to have this problem got owww/garmin.com/usbgpsfaq. i have not so far been able to get there HELP !!!!
i have wasted too much time trying to get a brand new (gift) garmin GPS C340 to work. It keeps coming up with a street map of Kansas City. Not much help, I live in Ontario.
Your product is a piece of expensive junk.
ANYONE ELSE, DONT BUY IT......
I have the same issue.
Raymond
I loaded the disk -plugged in the USB cord to both computer and GPS,- the started the software but the hardware wizard tried to do the job. After trying to get rid of it the software from Garmin would not accept any input from me either in the form of deleting or removing a cord..
[email protected]
stuck in kansas map ,want home map to be connecticut..
have kansas map,want to be in connecticut,,computer will not allow me to download cd?????
I've got a similar problem, but I'm working with the garmin etrex legend and trying to down load gps coords. from geocaching .com. I've went to the URL after it directed me there. It seems my computer wont recognize the gps. Any tips.
can,t loadmap update,error message. can,t find ( gmnusb.sys )
When I plug in the unit I get the message to check the Garmin web site and can go no farther.
if you continue to get this error please check the following url for additional information athttp://www.garmin.com/usbgpsfaq
I inserted the CD with the USB Drivers connected to the Garmin (powered on). and it said go to this URL for help if you continue to receive the error message. Big whoopy, this is no help.
wont load map
I bought the cable device turned on the gps and it still tells me that
the system can not find it.
he says the system cannot find it,no new hardware found
I have followed the steps listed. When I try to load the maps, it says it can't load it to my memory card.
can not download drivers
i tried to download the driver for gps c330 and it wont let me i keep getting error message saying to http//www.garmin.com/usbgpsfaq ....im able to charge my garmin with my usb connected to the computer but had never downloaded thedriver and now iwant to load more maps and have no idea how to go about this i got a notification on gps tellingme it was time to download more updated maps etc ..so help me out pls thanks gloria byron ...
Garmin Streetpilot i5will not run
same exact problem as described on the previous page
I have the same problem as described below:
Try to load from cd that was load into computer and followed on screen instructions now connect the usb cable from GPS to computer and went to some steps and at one point on screen will say, not communicating with gps memory card. A message says if you continue to get this error, please check the following URL for additional information www.garmin.com/usbgpsfaq. PLease help me out so i can use my Garmin Streetpilot i3 gps.
cannot load map to memory card with cd provided with usb cable
Yes ,i have the same problem ,Trying to instal Garmin USB driver ,follow instruction ,turn on Garmin GPS ,connect USB cable , Get mesage to turn on GPS to continu , (it is on) and i keep having this message ( If you continue getting this error please check the following URL for additionnal information . www.gramin.com/usbgpsfaq
may be a driver download problem-not sure. The window pops up saying that I need to connect the gps to the computer - IT IS. The window directs me to the web site
It keep saying can not see my garmin
memory card nor found
STREETPILOT C 320....WILL NOT LOAD MAPS.. ERROR MSG. IF YOU KEEP GETTING THIS MSG. GO TO WWW.GARMIN.COM/USBGPSFAQ.......SO WHERES THE FIX? I PURCHASED FOR CHRISTMAS AND STILL CANT USE. WHAT A PIECE OF CRAP!
