SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press 4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
SOURCE: Alpine CDE 7853 removal
remove the face and then the trim ring for face you should see 2 little pins on either side of the radio slide them up and it should slide right out
SOURCE: Wiring schematic for Alpine CDE-7856
Download user's guide and go to page # 20 for wiring diagram.
SOURCE: I had an Alpine CDE 7870 Cd player in my Chevy van
go to an audio shop for the stereo kit for that model year vehicle. you can also try wal mart and best buy.
Testimonial: "Great advice, most helpful. I'll try it ASAP!"
SOURCE: alpine
YOU MAY BE ABLE TO GET A HARNESSADAPTOR. IF NOT GET AN "ISO" PLUG FROM YOUR FACTORS, AND FOLLOW THE INSTRUCTIONS ON THE PACK, 1 PLUG IS THE POWER PLUG SO FIND THE SWITCHED LIVE, CONSTENT LIVE AND GROUND FROM CAR SOCKET. THE YELLOW IS CONSENT/MEMORY RED SWITCHED, BLACK GROUND EARTH, THE SPEAKER LEADS ARE PAIRED BY COLOUR YOU CAN TEST THESE WTH A 9V BATTERY TO FIND WHICH ONE IS WHAT, THE SPEAKER WILL BUZZ
