Marantz DV4001 DVD Player Logo
A
Anonymous Posted on Oct 10, 2013
Won't turn on - rental dvd stuck in dvd - any way to open the disk tray?
Marantz DV4001 DVD player suddenly won't power up. Rental DVD stuck in player. Besides the lack of power issue - is there way to open the DVD player manually?
YES, UNPLUG, REMOVE SCREWS @ BACK & SIDES, CHANGE FUSE ON POWER BOARD,OR YOU CAN TRY & RELEASE THE TRAY BY WINDING THE COGS BACKWARDS. CHECK YOUR PLUG FUSE FIRST.
4helpful
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
I have a GPX D200B DVD Player and cant get the Disk Tray to open.
unplugged the dvd player and then re plugged, power on then press the eject button. if still the loading tray won't open, at this time you will need to remove the cover of the player to access the loading tray mechanical assembly. then check for an stuck up or broken rail plastic loading assembly it was installed drive by the loading motor.if ok, check the limit switch might not get contact which the processor not turn on the supply for the motor.
Toshiba MD14H63 dvd stuck in tray won't play region code error
Someone is going to have to open the unit and see if they can cycle the disc out by hand or not.
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Dvd is stuck inside and drawer will not open
Yes, it was a piece of the addhesive dot that was stuck to the back of the disk. I unplugged the unit (of course), removed the 10 screws holding the cover on the chassis and that exposed the disk in its tray. I could not manually open the tray still, but I was able to remove the tape dot from the disk while it was still in its tray. All is well now.
Won't power up. Disk stuck inside. Can i open that tray to rescue my rental?
take a small flat head and pry the door open if not the only other way is to unscrew cover and manually push tray open
E1 (rear) error. DVD tray will not open.
there might be a possibility that as soon as the tray closed the dvd shifted inside the machine. the dvd is stuck yes which means that the tray wont open because the dvd is blocking the gear turning. if so you are going to have to take it to your Dealership to open up the player and remove the disk. you can try it yourself but it's not recommended. tray gears will have to be tested to see if the tray will open once the disk is out though
Dvd burner won' eject dvd
On the front of the burner there is a pin hole. Take a paperclip and unfold it so it's a point. Stick it in the hole and it should open the tray. This should FixYa!
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck [email protected]
Top Marantz Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
