Arris SURFboard SB4220 Modem Logo
A
Anonymous Posted on Oct 09, 2013
Troubleshooting motorola 4220 it is conec to T mobile and the blue light no turn on
How do I pair my Motorola H500 headset to my Iphone 4s, it keeps searching> Is is compatible
Turn your h500 off. Then long press the multifunction button untilnit lights up steady blue. Then search on your phone to locate and pair with the headset.
Mark
Motorola Support
tip
How to connect a (Motorola) Blue Tooth headset to a mobile phone!
The following procedure is dependent to the phone in use! However it is mainly for Motorola brand but it works with many others too!
1. Turn on your mobile phones bluetooth function and go to search for new devices menu.
2. On the headset, From turned off state, Try holding down the power button for at least 5 seconds.
- The light should stay constantly on (or in other brands flashining very fast) which means the headset is in receiving/searching state!
3. search in your mobile phone for blue tooth devices(the phone and headset shouldn't be more than 5 meters away from each other )
4. When you find your blue tooth headset, chose it and hit "connect" or "pair" with the device!
5. you will be asked for a pin, put in "0000" and ok!
now your headset should be paired with your phone (the light flashes slowly) and will be ready to receive calls!
Best wishes
Bruce
on Jan 27, 2010 • Cell Phones
3answers
Motorola H730 will not turn on even though it is fully charged
Karen-
Are you getting a steady blue light when you follow the pairing procedure? Or are you unable to get it to stay on stead?https://www.motorola.com/moto_care/manuals/BT/H730_QSG.pdf
Mark
Forums Manager
Droid x wont turn on just green light on charge
Hello Anonymous.
In order to know what is causing your device not to turn on, you can go to our Motorola Website and follow the instructions and troubleshoot with the phone to isolate and resolve the problem: Motorola Support Find Answers Motorola Mobility Inc
Motorola hs850 bluetooth headset won't pair with g five mobile
How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
  4. (Now you can let go of the call button.)
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
I have charged the blue tooth but I do not know how to turn it on to pair it with my phone
Well, try to press the Call button: it is the button that has got telephone drawed. Hold it until you see the blue light steadily lit. That means that you just turned on and putted the headset into pairing mode. Now find Motorola H500 over your mobile phone. You will need to put a pass, and it is by default (i think, on ALL Motorola Headsets): 0000. You're ready for using!
10helpful
2answers
How do i run my motorola h505. I got it from a friend and have no idea how to use it.
the following procedure is dependent to the phone in use!
2. On the Moto headset, From turned of state, Try holding down the power button for at least 5 seconds.
now your headset should be paired with your phone and work for receiving calls!
Great Success :P
Bruce
3helpful
How do i place a h555 motorola bluetooyh in pairing mode
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Call button
towards the microphone to initiate easy
pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate
headset is in pairing mode.
Step B - SET YOUR PHONE TO LOOK FOR
YOUR HEADSET
On your Motorola phone, press (Menu) >
Settings > Connection > Bluetooth Link >
Handsfree > Look for Devices.
The phone lists Bluetooth devices it finds.
Select Motorola H555.
Select OK or Yes to pair your headset with
your phone.
Enter the passkey: 0000
Select OK.
When your headset successfully pairs and
connects with your phone, the indicator light
changes from steadily lit to flashing blue.
Troubleshooting: Make sure that any devices previously pairedwith the headset are turned off. If the indicator
light is not steadily lit in blue, turn off both the
other device and headset, wait 10 seconds,
then turn headset back on. Wait for the indicator
light to become steadily lit in blue, indicating
the headset is now in pairing mode.
User Manual
1helpful
4answers
Top Arris Computers & Internet Experts
Jesse Walters
Jesse Walters
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
