Question about Texas Instruments TI-86 Calculator
17/4 as a percent - Texas Instruments TI-86 Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
425%
Posted on Jun 20, 2014
Number of days past the due date as a percentage?
That would depend on the terms of the payment. Two days late on a daily payment would be 200% while two days late on an annual payment would be about half a percent.
Jul 29, 2013 | Computers & Internet
P0068 map/maf throttle position correlation
Hi there:Here's the printout from the diagnostic tool. Year: 2006Manufacturer: ChryslerMake: DodgeModel: DurangoEngine Type: V8, 4.7LTransmission: AutomaticTrim Level: SLTMileage: 127555 KMs
=== Stored Error Code(s) ===Error Code: P2074Possible Causes: Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Higher LoadError Code: P0068Possible Causes: MAP / MAF - Throttle Position Correlation
Freeze Frame Information:1. DTC for which Freeze Frame was Stored - P2074.2. Fuel System 1 Status - Closed Loop.3. Fuel System 2 Status - Closed Loop.4. Calculated LOAD Value - 74.51 percent.5. Engine Coolant Temp - 199.40 degrees F.6. Short Term Fuel Trim - Bank 1 - -3.91 percent.7. Long Term Fuel Trim - Bank 1 - -3.13 percent.8. Short Term Fuel Trim - Bank 2 - 0.78 percent.9. Long Term Fuel Trim - Bank 2 - -4.69 percent.10. Intake Manifold Absolute Pressure - 22.21 Inhg.11. Engine RPM - 2,404.00 Rpm.12. Vehicle Speed Sensor - 73.94 Mph.13. Ignition Timing Advance #1 Cylinder - 25.50 degrees.14. Intake Air Temperature - 64.40 defrees F.15. Absolute Throttle Position - 31.37 percent.16. Time Since Engine Start - 1212 Sec.17. Commanded EGR - 7.06 percent.18. EGR Error - 0.00 percent.19. Commanded Evaporative Purge - 62.35 percent.20. Fuel Level Input - 93.73 percent.21. Barometric Pressure - 26.35 Inhg.22. Control Module Voltage - 14.35 V.23. Absolute Load Value - 0.00 percent.24. Commanded Equivalence Ratio - 0.00.25. Relative Throttle Position - 0.00 percent.26. Ambient Air Temperature - -40.00 degrees F.
Monitor Information:1. MIL - OFF.2. Misfire Monitor - Complete.3. Fuel System Monitor - Complete.4. CCM Monitor - Complete.5. Catalyst Monitor - Complete.6. Heated Catalyst Monitor - Not Supported.7. EVAP Monitor - Complete.8. Secondary Air System Monitor - Not Supported.9. O2 Sensor Monitor - Complete.10. O2 Sensor Heater Monitor - Complete.11. EGR Monitor - Complete.12. NMHC Monitor - Not Supported.13. Nox Adsorber Monitor - Not Supported.14. Boost Pressure System Monitor - Not Supported.15. Exhaust Gas Sensor Monitor - Not Supported.16. PM Filter Monitor - Not Supported.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Mar 04, 2012 | 2005 Dodge Durango SLT
239700 is what percent lower than 288169
100*(1-239700/288169) or about 17%.
Since you didn't specify the make and model of your calculator, I'm afraid I can't give you the exact sequence of keystrokes to calculate this result.
Aug 03, 2011 | Office Equipment & Supplies
What is 17 percent of 50?
You can just divide 17 by 100 (percent) and multiply by 50 e.g. 0.17*50 = 8.5
Mar 10, 2011 | Texas Instruments TI-83 Plus Calculator
College algebra
a bookstore purchased a best selling price at 200 pesos per copy. at what price should this book be sold so that, giving a 20% discount, the profit is 30 %?: a bookstore purchased a best selling price at 200 pesos per copy. at what price should this book be sold so that, giving a 20% discount, the profit is 30 %?
Aaron works part time as a salesperson for an electronics store. He earns $6.75 per hour plus a percent commission on all of his sales. Last week Aaron worked 17 hours and earned a gross income of $290.63. Find Aaron’s percent commission if his total sales for the week were $3,350. If necessary, round your answer to the nearest hundredth of a percent.
A cross-section of a standard or normal "two-by-four" board actually measures 1 1/2 in. by 3 1/2 in. The rough board is 2in. by 4in. but is planed and dried to the finished size. What percent of the wood is removed in planing and drying?
A new fax machine was purchased for an office in HopeDale for $464.40 including tax. If the tax rate is 8 % , find the price of the fax machine before taxes.
Oct 01, 2008 | Computers & Internet
Texas Instruments TI-86 Calculator Logo
27 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
